idle keeps dropping??
Old Jan 17, 2008 | 09:48 PM
evo8nyc's Avatar
alrite heres the issue i switched my 3"TBE exhaust which was buschur great piece by the way. With a greddy TI but i kept the BR downpipe and put a turbo XS testpipe. So after install once i get on the car and come to a stop like a light the idle seems to drop and bounce back up i was tuned for my BR TBE could i have to be Retuned for this one? any input would be helpful thanks guys/gals
Old Jan 17, 2008 | 10:07 PM
evo8nyc's Avatar
anyone?
Old Jan 18, 2008 | 05:26 AM
C6C6CH3vo's Avatar
Idle problems on evos can suck dude. I had a problem that would be random where the idle would go north of 2500rpm. It would make me upset and ruin my day. Found out it is code related with my ECU, possibly from overflashing, a logging malfunction that occured, or from an old flash that I got over two years ago no longer in use except for some remaining bad code.
I got fed up and totally deactivated the entire idle system on the car, blocking the idle bypass, removing the stepper connector, then adjusting with BISS. Now, except for cold starts, my car has never idled so consistant since I bought the car with 18 miles on the tach 4 years ago. Stays at 850.
Check the PVC for blockage, that can make it stall, and don't touch the factory set BISS unless you absolutely have to
Old Jan 18, 2008 | 11:00 AM
evo8nyc's Avatar
anyone els with a ix have this problem
WickedMRsiNY
Sep 7, 2010 09:15 AM
mlee25
Apr 17, 2010 12:33 AM
slvrr
South Region
Aug 26, 2008 06:29 PM
Muad
Aug 20, 2007 01:25 PM
monies41
15
Aug 27, 2006 07:55 AM
