924 whp EVO VIII and crankshaft
Old Jan 24, 2008 | 09:45 AM
JVELA's Avatar
How good in an stock Evo VIII crankshaft. What is the most power it will hold without problem. I recently found that at this power level apparently an stock block didn't hold. I made an small crack on cylinder 1 with that power. The question is does an stock crankshaft will hold fine???
Thanks.
Old Jan 24, 2008 | 09:48 AM
AWD Motorsports's Avatar
stock crank is fine from my experience and research.. The cylinders do crack on big HP sometimes.. for extra reliability you can cement fill the block and run alcohol..
Old Jan 24, 2008 | 09:49 AM
BURNALL_4's Avatar
im almost positive that buschur, dynoflash and Pauls car all run stock cranks. Im sure there's more tho.
Old Jan 24, 2008 | 09:50 AM
gixxerman11's Avatar
^^^ what he said
Old Jan 24, 2008 | 09:57 AM
JVELA's Avatar
Thanks!
I'm building a new motor, will be back on 3 weeks. Lets see what happen this time, lots of new things. hehehe
Good luck USP!!
Old Jan 24, 2008 | 10:28 AM
9sec9's Avatar
USPMotorsports, is the alcohol easier on the block and internals than gasoline? 'Longer' burn result?
Old Jan 24, 2008 | 10:38 AM
hopper's Avatar
I think its because alcohol burns cooler 9sec9
Old Jan 24, 2008 | 10:39 AM
scorke's Avatar
It runs signifigantly cooler I believe this is why you can run it and fill the block, you don't need to worry about cooling it with the alcohol.
Scorke
Old Jan 24, 2008 | 10:40 AM
scorke's Avatar
Shizzle, 1 second too late
9sec9 im pretty sure the internals just care about rpm and boost, nothing else. Alcohol might do a better job of getting past the rings but im not sure its significant as I dont have any personal experience with it.
Scorke
Old Jan 24, 2008 | 12:31 PM
I dont have much experience with alcohol myself but my tuner does alot of alcohol rotaries. From what i understand with alcohol you can fill the block because alcohol does have a cooling affect. Many guys run no radiator, and no intercooler on alcohol.
Old Jan 24, 2008 | 04:06 PM
hopper's Avatar
Scorke
Great minds think alike
Old Jan 24, 2008 | 04:43 PM
20Grockit's Avatar
If i did anything to the crank id just get it balanced, blueprinted and polished.
Old Jan 24, 2008 | 04:47 PM
Billy@EnglishRacing's Avatar
Paul's car is on a stock crank and holds up fine
Old Jan 24, 2008 | 05:26 PM
Paul Nelson's Avatar
The cracks seem to happen i have 3 cranks with stress cracks under the magnaflux.
But we have never have one break.
Old Jan 24, 2008 | 05:30 PM
Curt@MrLed's Avatar
Former Vendor
Thats still amazing 900 horse on a stock crank.
