IX Turbo issues
Old Jan 31, 2008 | 03:47 PM
Maddy88's Avatar
IX Turbo issues
Stock IX turbo boost goes from 1.3 to 1.0 to .80 bar. at roughly 3800rpm to 5k. this is a new turbo installed from the dealer just got the car back today and boost gains and loss is really odd any suggestions. Thanks
Old Jan 31, 2008 | 03:50 PM
IEXCELR8's Avatar
Check all your IC pipes and hoses.
Old Jan 31, 2008 | 04:01 PM
Maddy88's Avatar
yeah i was thinking that could it be the ecu
Old Jan 31, 2008 | 04:43 PM
sparky's Avatar
If the turbo was installed at the dealership, why not go back and have the mechanic that installed the turbo do a follow up check? Didn't they road test the car?
Old Jan 31, 2008 | 04:54 PM
Maddy88's Avatar
yeah they supposedly did a test drive on it but i'm in WV so yeah some stealerships don't even know what an evo is let alone know how it works
Old Jan 31, 2008 | 05:17 PM
sparky's Avatar
Did you pull the airbox and check the hose connections to the boost control solenoid? Also check the reference hose that is on the compressor housing discharge nipple, and the hose that hooks up to the nipple on the MAF tube, as well as the tightness of the hoses on the diverter valve and the wastegate actuator.
Old Jan 31, 2008 | 07:34 PM
20Grockit's Avatar
check all your ic pipe connections and lines going from turbo and wastegate to the boost control solenoid.
