Normal PTE880 fitment?
Old Feb 1, 2008 | 03:34 PM
kaonashi's Avatar
Just making sure this looks right, before it sat flush but its all snug.
Old Feb 1, 2008 | 03:39 PM
L80Killa87's Avatar
Is that bar not sitting flush with the black thing?
Old Feb 1, 2008 | 03:43 PM
kaonashi's Avatar
well fuel rail is but the golden fuel presure line isnt
Old Feb 1, 2008 | 03:46 PM
L80Killa87's Avatar
I think its supposed to all sit flush. I think mine sits flush, I have ptes and I think everything was flush.
Old Feb 1, 2008 | 03:47 PM
kaonashi's Avatar
I will go wiggle it while its lose and see if i can make it fit better
L80Killa87's Avatar
Try that. I will run and look at mine in a sec.
Old Feb 1, 2008 | 03:53 PM
L80Killa87's Avatar
Looks like mine is the same way.
Old Feb 1, 2008 | 03:54 PM
Aby@MIL.SPEC's Avatar
i had to run a washer of ~0.060" under each fuel spacer / black phenolic piece, so my injectors would twist, as the oem injectors did.
the pte injector to manifold o-rings are garbage....as they cracked really bad in less than a year. use oem pieces.
Old Feb 1, 2008 | 03:58 PM
kaonashi's Avatar
i did use the oem pieces lol, oh well its all snug tight it cant move i just didnt know if it was suppose to sit flat
Old Feb 1, 2008 | 04:20 PM
dubbleugly01's Avatar
it's supposed to sit flat. I'm running PTE 880's, and these and the 780's all sat flush. Your phenolic spacer is cocked, or crooked. Loosen the bolt, giggle it around, and it'll sit flush from there. I ran into the same problem on my install, but with some work, you'll get it to sit flush.
If you're worried about it, pull a PTE injector and compare the length to a stocker. Then you'll be convinced it should sit just like stock. GL!
Old Feb 1, 2008 | 04:23 PM
kaonashi's Avatar
my stock ones are gone, i loosend all the 2 bolts and wiggled it freely it wont sit any flatter then it is.
AWDTerror
Jan 4, 2010 08:21 AM
AWDTerror
Nov 22, 2009 12:03 AM
AWDTerror
Nov 3, 2009 03:59 PM
AWDTerror
Oct 29, 2009 06:01 PM
