Help With Meth
Old Feb 4, 2008 | 05:40 PM
Celica2EVO's Avatar
Help With Meth
Hey guys, I am about to install my Snow Meth Kit with the Trunk Mount Tank. My question is what is the best thing to use for the hose, and where did you run your hoses? Where through or Under the car did you run them and hook them to? Thanks!
Old Feb 4, 2008 | 05:45 PM
Ultimate CC's Avatar
I typically run the hose down the passenger side under the door sills and then out through the firewall...but you can also run them under the car pretty easily through several hose in the trunk...
Old Feb 4, 2008 | 05:49 PM
Celica2EVO's Avatar
Ok, I was thinking that I would run it down under the passenger door sill, what is the best size hose to use? Im not sure if the guy sent me the hose or not. Thanks for your help!
Old Feb 4, 2008 | 05:52 PM
I typically send 20ft which gives you plenty of room...if you have any less than 15 you may be cutting it close...
Old Feb 4, 2008 | 05:58 PM
Celica2EVO's Avatar
Sorry, stated that wrong, what size of say fuel hose (I.D.) would you use, not the length, but the Inside Diameter?
voltexct9a
17
Sep 5, 2012 07:41 AM
discodino
Jul 26, 2008 02:01 PM
Pure Playaer
Jan 3, 2008 09:17 PM
thedragon
Dec 8, 2007 08:07 PM
dryad001
11
Oct 6, 2005 02:14 PM
