Extreme Turbo Systems Does it again! 45r working with a Stock Radiator and more...
My divided T4 manifold fits a gt42 behind the stock radiator as well and that has been out since 2003.
It was good to meet you down at sema. Ron your manifolds are top notch alsoPlease edit your thread and do not come in here to start a vendor war
Thanks for the kind words Paul. It was too bad you had to leave Vegas that night everyone went out. We had a good time.
I'm not into Vendor wars nor am I doing any bashing. I don't have time for that and I'd rather use my extra energy to get more crap done around here or getting some fresh tail. From the looks of things ETS has served you very well.
Generalizing that using a lot of filler rod, to achive a convex shaped and wide bead, makes for a strong weld is not true. That was my point, nothing less and nothing more.
Although I run a half radiator - it does fit 100% the stock radiator
Interestingly, I have never had any over heating problems with the half radiator.
Thanks as always for your manifold - it has performed 100% and never a crack
AL
Our welds have a wider and more convex bead mainly because our elbows have a larger chamfer. The reason for the larger chamfer is so that there is more surface area in the welded zone, which results more welded area per joint. Because of the chamfer, we are also able to make sure the weld is fully penetrated, we are able to see the deepest part of the weld as we are welding, this has resulted in more consistent welds than relying upon penetration alone.
The convex outward appearance is correct for the chamfer, and thickness of the material being welded. If there was no chamfer, and we just piled a bunch of rod on top of two butted pipes, then it would be no better, or even worse than a regular, well penetrated weld. Please see the pics for a comparison of our chamfer and a conventional chamfer.
I should know master Shearer you sold me on of the first ones!
AL
AL
Didnt get back to the motel till 5am
your work is fantastic. altough your website dosen't show any T4 divided manifolds ofr the Evo. i thought they used to be on there.
Chris.
I am very impressed! I am very proud to be running ETS's FMIC this season. can't wait to see what the have in store next, keep up the great work guys!!! That manifold on your evo Paul is pure sex! I'm jealous!
Sweet
