Got GT3582FP turbo
Old Feb 16, 2008 | 05:29 PM
Slava's Avatar
Got GT3582FP turbo
Got HTA GT3582FP turbo
So I had to clock turbo and I took it apart and I saw that there was no o-ring between these 2 parts.
Is it supposed to be that way or they just forgot to put it??
Thanks.
Old Feb 16, 2008 | 06:55 PM
CO_VR4's Avatar
Slava,
Glad to see it arrived safely. I've forwarded your question to Forced Performance, and will have you an answer quickly.
Old Feb 16, 2008 | 06:58 PM
EvoRecordSetter's Avatar
what does this mean " So I had to clock turbo " .
im sure they sent the turbo the way its supposed to be.. why would they take an o-ring out?
Old Feb 16, 2008 | 07:40 PM
vwjeff's Avatar
No o-ring required, FP will tell ya the samething
Old Feb 16, 2008 | 08:15 PM
Slava's Avatar
I thought there should be one. I am not sure but my stock evo9 turbo had it.
They might have designed it this way but there will be 30PSI and it might leak because it is just 2 aluminum surfaces.
Old Feb 16, 2008 | 08:17 PM
Slava's Avatar
Originally Posted by CO_VR4
Slava,
Thanks man. It arrived perfect i had some issues with customs but that is always same deal.
I already sent e-mail to FP techs.
Old Feb 16, 2008 | 08:20 PM
Slava's Avatar
Compressor outlet was not clearing cylinder block. That is why i had to clock it. It is normal procedure it just depends on which manifold you use. I never said they took it of i said that they might have forgot to put it during assembly.
Old Feb 16, 2008 | 08:36 PM
V8 Eata's Avatar
I want your turbo in the worst way!
Old Feb 16, 2008 | 09:00 PM
CO_VR4's Avatar
Slava;
VWJeff is correct.
Here is the response from Forced Performance, within three hours on a weekend:
The turbo uses a Garrett T4S compressor housing and seal plate setup. For reasons unknown to me or anyone else from what I have been able to gather over the years, Garrett did not incorporate an o-ring into the design of these parts. The T4E and T4B covers DO use o-rings for what that is worth.
Normally nothing is done about the parasitic leak that exists there (the parts fix quite tightly), but in applications where such parasitic leakage is unacceptable or results in fuel leakage I suggest red RTV sealant be applied between the cover and the seal plate adapter once final orientation has been determined within the engine compartment. Only a VERY small amount of sealant should be used. The seal plate adapter does use an o-ring where it seals with the bearing housing, so no extra attention is ever required there.
Best Regards
Forced Performance
Hope that puts your mind at rest.
Old Feb 17, 2008 | 04:04 AM
Slava's Avatar
Slava;
VWJeff is correct.
Best Regards
Forced Performance
Thank you very much. That helps allot. I contacted few other guys and it seems like garret did not used o-ring at all on new compressor housings.
Thanks for your help. And i will probably use some red hi temp sealant to stop parasitic leakage or i might make gasket if i wont be too lazy.
Old Feb 17, 2008 | 11:22 AM
TiALSport's Avatar
i honestly wouldn't even bother with it, it has an o-ring between the CHRA and smaller circle...and if you ever want to take the housing apart agian it's going to be a major pain
ku7484
Jan 26, 2011 05:28 AM
Goldfinger978
Oct 28, 2008 02:16 AM
Goldfinger978
Jun 18, 2008 08:11 PM
J8dailo
Aug 27, 2007 01:28 AM
