ACT 6 puck sprung or unsprung?
go sprung! I am currently running it in my act hdss. The sprung will be a little bit smoother engagement and less stress on the drivline. Either way the 6puck is going to be a little rugher on engagment. Good luck
6 puck sprung - less noise on deceleration because of the springs, virtually the same harsh engagement as the solid hub version (friction material unchanged between the two discs), more weight = slower shifting compared to the solid hub version because of the extra parts and it will cost more because of the additional parts to build compared to the solid hub version.
6 puck solid - the opposite of what I have listed above the sprung version.
That is correct, the primary reason the springs are on any disc is to eliminate torsional vibration or the coffee grinder sound that people complain about (the site also says that too). Per my other post both discs will offer "virtually the same harsh engagement".
http://www.advancedclutch.com/products/racediscs.aspx
go w/ the sprung 6 puck, I have the ACT HD w/ sprung 6 puck and love it. Its not the most fun setup to drive, but it holds the power. I have a friend who has the ACT street setup and its not as stiff and a little better drivability.
One other benefit of the spring center is the the disc splines will last longer since the springs dampen out the pulses, so don't expect to get high mileage on a solid center disc.
wow, you east coast guys r so lucky using 93 gas, in socal only 91 sucks for us....
omg.. 372 whp?? WOW!!! i cant believe that...
-HKS Hi-Power
-Buschur Intake
-Helix V2 downpipe
-Borla Manifold
-Helix test pipe
-Megan 02 housing
-Hallman MBC
-Ebay FMIC
-ETS LICP
372whp/356wtq 11.8@116 1.75 60' Stock turbo, cams and 93 octane
A Ridiculous 4 Wheel Slide Tune.......Cause I Spit Hot Fire
-HKS Hi-Power
-Buschur Intake
-Helix V2 downpipe
-Borla Manifold
-Helix test pipe
-Megan 02 housing
-Hallman MBC
-Ebay FMIC
-ETS LICP
-HKS Hi-Power
-Buschur Intake
-Helix V2 downpipe
-Borla Manifold
-Helix test pipe
-Megan 02 housing
-Hallman MBC
-Ebay FMIC
-ETS LICP
-HKS Hi-Power
-Buschur Intake
-Helix V2 downpipe
-Borla Manifold
-Helix test pipe
-Megan 02 housing
-Hallman MBC
-Ebay FMIC
-ETS LICP
