Need part# for T-case bearings!! Help!!
Old Feb 18, 2008 | 06:34 PM
dueces's Avatar
Hey guys, I blew my spiders in my stock 03 diff., so I got a RS LSD. Well the carrage case that the RS LSD came in isn't completely the same as my carrage case, So I can't just swap the whole carrage in, BUT, my stock carrage is so F'ed up, that I can't use the larger half of the carrage. Well the new carrage happens to be the same for that half of the carrage, so I'm going to use it, but I can't pull the stock bearing off of mine, so I'm trying to source a new bearing.
I went to the dealership and talked to the parts department about getting a new bearing, and low and behold they can't get a new one!!!! WTF!
So If anyone has the part number for the bearing that is on the driverside of the carrage case, I am in deep need!
Thanks in advance guys
John
Old Feb 18, 2008 | 09:21 PM
joeracer321's Avatar
I looked in Mitsu CAPS & I don't think that those parts are available from the dealer. You will probably have to contact a junkyard, call Sheppard or TRE. They may be able to help you
Old Feb 19, 2008 | 03:49 AM
dueces's Avatar
Thanks for the response, I'll give um a call.
John
