1000cc or 850cc
1000cc or 850cc
Ok I am starting my Top secret Project moleasses,
Can someone explain the advantages of getting 1000cc instead of 850cc injectors?
Stock turbo....for now
Im getting other little goodies aswell, I just wanted to clarify the difference in them, besides the obvious cc difference
SJ
SJ
Well I cant really tell what they look like from the pic but they look complete,
Will I be able to use these in the mean time, or will i have to wait until I break 28 lbs?
brand is N/a right now but I will find out
SJ
SJ
I was running the stockers in my 05 without a problem until I put the HD wastegate actuator from forge on it. Finally hit the fuel cut. My mods to that point where as follows: 264I/ 272E cams, AEM Tru time cam gears, FMIC, Injen intake and UICP, AMS LICP, Bushcur 3" TBE, o2 housing, tubular manifold, ARP head studs, blitz SBC i-D set to 20psi holding till redline, Cusco twin disc clutch, also it was about 40 degrees out the morning I hit the fuel cut. Felt like hitting a curb!
Josh
Josh
These are precision injectors. He said seals still good and everything complete, i think I will get them anyways, and run stockers untill i get to that point....225 sounds good to me
SJ
SJ
I wouldn't just get no name injector - if your purchasing injectors be sure they come from a reputable place. PTE and FIC use delphi injectors which are a lot better than lucas style. I know FIC test each injector and matches a set that all flow identical, this is all very important if you want to keep the motor from going kaboom. I am sure PTE does the same as well.......
My theory is never go cheap on the fuel system of a turbo car, its the most vital thing to keep the car alive.
