Bigger intercooler on stock EVO
I'll sell you mine for $699
You said the stock IC was slightly damaged? does that mean it absolutely needs to be replaced? If this is true and your really not planning to mod the car otherwise, plus your concerned/parinoid about your warranty, then find a nice used stock IC. With all the after market IC's out there and so many people modifing there cars. You should be able to find a nice used stock IC for a very reasonable price.
Originally posted by Chris in HB
If I have the RMR intake, turbo-back exhaust, intercooler hardpipe and ECU flash, what kind of gains from a larger intercooler should I expect?
Originally posted by SILVER SURFER
The man said stock, MBC and AFC is not stock. I believe people are running mid 12's or better on the stock intercooler also, so what. This still does not answer the question; On a completely (and I mean absolutely no other modifications) stock car, how much HP/TQ will you gain (if any) from just replacing the intercooler.
The only test data I have seen shows the stock intercooler has only a 2-3 PSI pressure drop on a modified car running 22-23 PSI, (not bad at all).
Anyone else care to chime in about whether a larger IC on a stock car will do anything? Opinions thus far have been mixed, but I'd love to hear what others have to say. Thanks.
These were not entirely serious offers, honestly a reasonable price on a used stock IC should be $300-$400, in another 6-9 months you will be able to find them for around $200 or less.
With all the people upgrading there cars, there will be quite a few of these things sitting in peoples garages. I have a bunch of stock FD RX7 parts that I will sell/give away real cheap.
Re: hmmm........
Originally posted by 0to60n5
New Import Tuner magazine. XS engineering tested a EVO with new intercooloer and dyno after install with a gain of only 1 hp at the wheel. Not enough for me to drop 1,000
Yeah that was on a dyno.
Without the car moving through the air like driving, that means it still made a gain. I have a road dyno and if anyone gets an IC in my area I am happy to test it to see what it really does for the car.
Again the usefulness of this mod will nto be recognised at a stock level, but when you start modding, it will keep crazy boost and heat levels stable and acceptable, so the car will have low knock, and ample timing, that is the name of the turbo game.
It would seem that if your Ic wasn't running efficiently, you would actually lose power from all the pressure that it would have to build through the higher volume intercooler. Yes the temps are much lower, only because you are increasing area of heat to disipate. You better bet would be CO2 spray!(much cheaper, and you would only use it when you feel necessary.
I do not think anyone is questioning that a larger IC will have improver air flow and cooling efficiency. It's just that the stock unit works so well in stock/mildy modified cars, there just does not seem to be much benefit for the money. Unless you plan to go with a larger turbo and make over 350-400HP.
