Aeromotive fuel pumps?
ams sells them i believe.... what setup are you running to need that much fuel?
Buschur has a dual walbro setup that works very well. It drops right in and doesnt need anything fancy.
Cheers!
Cheers!
From my experience, an A1000 will be much louder than a dual fuel pump setup. Especially since they're usually externally mounted.
Since the second pump in the BR double pumper setup is staged via a Hobbes switch it isn´t on at all when you´re driving around at part throttle, low boost situations, or at idle. Under these conditions you´d just be hearing a single Walbro, same as stock noise level.
Most Aeroquip fp's use a -6 or-8 fuel line, which although mounts up to the stock fuel filter nicely, is an insane amount of fuel since stock is a -4, or -3 hard line. I ran a -6 line when I bent my sock fuel line off changing the fuel filter on my GST, and even with a 255 lph i could never correct the fuel its was so much flow that it was spraying more in my #1 because fouling the plugs because the FPR couldn't handle it.
Now if that tiny pump is THAT loud inside a fuel tank then just imagine what a bigger pump is going to sound like bolted to your trunk!
Lets put it this way the walbro fuel pump can be heard easily when the cap for the fuel pump cover is off and the back seat is out. I know because i did that this weekend to test out my fuel pump config.
