changing clutch
Old Jul 30, 2003 | 01:59 PM
EVILEVO13's Avatar
changing clutch
I have 6k on my evo and have to replace the clutch. Im thinking of replacing it with a clutch masters kit stage 3 for $795.00
Does anyone have any suggestions about that? And I also ordered a RMR intake, I heard different things like loss of power or having to disconntect the negative on the battery after you install it and idle so the computer adjusts?? Im lost
Old Jul 30, 2003 | 02:03 PM
ChillinEvolved's Avatar
In Timeout
disc the battery will reset your ecu.. so your ecu will start from scratch and reprogram itself so yes it would be a smart thing to do so your comp gets the a/f ratios with the extra air flow comin in.... the loss of power may be true bcuz i lost a few hp/torque with my custom K&n intake from altered atmosphere..... but once u get fuel management it should help a lil bit...
Old Jul 30, 2003 | 03:39 PM
EVILEVO13's Avatar
Thanks, Anyone on the clutch problem? Should I give the dealer $750.00 or pay $1250.00 for the Clutch masters stage 3 clutch including install? The 750 for the dealer is also with install.
Old Jul 30, 2003 | 03:53 PM
IS2000's Avatar
$750 installed sounds like a great deal. Also, I have a question... why do you have to replace the clutch that soon? Do you drag race or go to track?
Old Jul 30, 2003 | 04:09 PM
EVILEVO13's Avatar
not at all just street racing, so you think I should just stay with the Mitsu clutch instead of the clutch masters(who claim that it is 110% stronger than stock)??
Old Jul 30, 2003 | 04:14 PM
EVILEVO13's Avatar
I just don't want my clutch to burn up again and thats why I would be willing to pay more for the stronger clutch but I really don't know much about clutchs. I also had an s2000 black 2002
loved it!
Old Jul 30, 2003 | 04:20 PM
Shahul X's Avatar
the evo clutch sucks.... dont waste your $750, go aftermarket....
-shahul
Old Jul 30, 2003 | 04:50 PM
TurboZ's Avatar
go aftermarket.
replace the hydralic clutch line to get rid of the check valve. that is why so many are going out.
Old Jul 30, 2003 | 05:26 PM
EVILEVO13's Avatar
Thanks Turboz & Shahul X, The Clutch Masters clutch is online at there website for a stage 3 design its $795.00. The mitsu dealership says that to install a clutch it cost $850.00 for labor!!
I am going to pick up the clutch tomm. And I got the dearlership to drop the price of install to 400.00. So a total of $1195.00 for a new clutch, there goes my idea of getting a RMR down pipe with exhuast!!
Old Jul 30, 2003 | 05:35 PM
timzcat's Avatar
Originally posted by TurboZ
go aftermarket.
you don't have to replace the line, just remove the restrictor at the slave cylinder.
And it is not proven that the restrictor is in fact the cause of all the failures, but it is a contributing factor.
EvoJimbo's Avatar
The Service Manager recommends me to get the JDM EVO8 clutch.
Old Jul 30, 2003 | 06:18 PM
Shahul X's Avatar
eh... Id still do an aftermarket vs oem/jdm....
Tell me more about the clutchmaster unit.... lemme know how noisy it is/isnt after you install it
-shahul
Old Jul 30, 2003 | 09:23 PM
EVILEVO13's Avatar
If I get the after market clutch and something goes wrong with my tranny will the dealership try and say that it was my non-mitsu clutchs fault?? Im so confused with what to and I need to make a decision fast because I need my daily driver back. FX300 (Stage III)
· Heavy-duty street & racing system
· Holding capacity 110% over stock
· Heavy-Duty reinforced pressure plate
· Hi-Leverage™ pressure ring design
· Sprung hub/cushioned disc
· Steel backed Segmented Carbon/Kevlar
All Clutch Masters systems come complete with:
Pressure Plate
Clutch Disc
Throw-out Bearing
Pilot Bearing or Bushing (when applicable)
Alignment Tool
Old Jul 30, 2003 | 09:44 PM
Diesel's Avatar
absolutely... but they have to prove it...
Old Jul 31, 2003 | 05:30 AM
Shahul X's Avatar
its only 110% more than stock???, stage 3???? Do they have it available right now? Hmmm....
Anyone know what the exedy twin disc comes with? throw out bearing also?
-Shahul
