Low ACD Fluid?
Old Mar 6, 2008 | 02:56 AM
Redline-Z's Avatar
Veteran: Air Force
Low ACD Fluid?
I have 10K on my IX and I just noticed today the ACD fluid is below the min. line when both cold/hot. Should I just top it off or is their a problem? I have no external leaks! TIA
Old Mar 6, 2008 | 05:45 AM
Davo's Avatar
check dealer, warranty should cover
Old Mar 6, 2008 | 08:18 AM
evospecialist's Avatar
just top it off with sp-3 approved atf as long as you have no leaks you will be fine.
Old Mar 6, 2008 | 09:13 AM
Jeff_Jeske's Avatar
Top it off excatly to the line then monitor.
