HTA 35R really worth it?
Old Mar 10, 2008 | 07:13 PM
  #61
David Buschur's Avatar
I found out today we have two FR twin scroll headers at the shop. The other is the same way but the actual head flange has been changed to have a slight "transition" machined into it, still has an abrupt change in size from the head port to the runner dimensions.
Old Mar 10, 2008 | 08:14 PM
  #62
JKav's Avatar
Equal length runners is not a goal unto itself. More accurately, the runners should have equal pressure drop.
This will balance the reversion equally across all four cylinders.
Although it should be said that if you have roughly the same number & acuteness of bends in all four runners, then making them equal length will result in roughly equal pressure drop.
If we were talking about helmholtz tuned runners, they'd have to be a LOT longer than what is typically used on turbo manifolds in order to be have a useful resonance. And these tuned runners will carry drawbacks of their own--additional volume, more heat loss, more pressure drop, less structural integrity... all are bad things in the context of turbo manifold design.
Old Mar 10, 2008 | 08:16 PM
  #63
Driven Innovations's Avatar
Very well said!!!
Old Mar 10, 2008 | 11:52 PM
  #64
ONRAILS's Avatar
Originally Posted by scorke
Different cars, different tuners, different dynos...
Scorke
scorke,
the ams kit uses a .63 hotside.
the HTA is a .82 turbo. That is where your added topend power came.
I really cant believe this wasn't brought up already. HTA is topend like a .82 and spool like a .63. AMS kids have always spooled so great because of the backside.
Old Mar 11, 2008 | 05:41 AM
  #65
deadbeatrec's Avatar
Ted B said it the best. runner design and size is a calculated process. same with the intake manifolds out there. u cant just expect to put the largest size runners imaginable and expect to make the most power.
Old Mar 11, 2008 | 08:08 AM
  #66
scorke's Avatar
Originally Posted by ONRAILS
scorke,
Well if the AMS test was .63 vs .63 and the FP was .82 vs .82 that might explain some of the discrepancy in the results, no?
Scorke
Old Mar 11, 2008 | 12:18 PM
  #67
ONRAILS's Avatar
the ams test was .63 non hta.. vs .82 hta.
Old Mar 11, 2008 | 12:22 PM
  #68
crcain's Avatar
Is that right? That sounds ridiculous.
Old Mar 11, 2008 | 12:38 PM
  #69
ONRAILS's Avatar
did you guys miss the boat where ams kits were .63's? They tested the .63 to make about the same power as the .82 and spool much better.
That combined with their header design is why they have spooled so well.
Their test isn't ridiculous its what it is. A ams kit vs a ams kit with the new hta turbo. They hta proves to spool like a .63 with a .82 backside.
Old Mar 11, 2008 | 06:23 PM
  #70
scorke's Avatar
The ams downpipe/o2 housing is made specifically for the 5 bolt .63 a/r hotside so you might be wrong, It would be need a goood bit of work to get the 4 bolt .82 to bolt up with the 02 housing.
Scorke
Old Mar 11, 2008 | 06:53 PM
  #71
crcain's Avatar
I run the HTA on a AMS 35R kit so I do know AMS uses a precision turbo .63 a/r. But it just seems odd to me that they wouldn't keep the turbine housing the same in testing HTA versus non-HTA since it's all a compressor side modification.
Old Mar 13, 2008 | 12:25 PM
  #72
diablo2184's Avatar
Graph a 37R vs a 35R on pump gas and that is the comparison.
A twin scroll 40R would be your cake and eat it too over a 35R, or just a twin scroll 35R over a regular 35R.
Scorke
now would you do the hta35r or a ts 40r? has there been any comparison to those?
Old Mar 13, 2008 | 01:24 PM
  #73
scorke's Avatar
Depends on the power and spool characteristics you wanted, I bet they would be similar with the 40R being able to put out a good bit more on full tilt.
There will probably never be a hta 35R and 40R twin scroll test, ever.
Scorke
Old Mar 13, 2008 | 01:30 PM
  #74
Nez136's Avatar
This is incorrect. Eric said in a previous post, the Turbos were both tested with .63 housings.
Old Mar 13, 2008 | 04:55 PM
  #75
diablo2184's Avatar
Scorke
Why wont there ever be a comparison you think? well i want something for the street but i like the power of the 40....people say that the 40 will spool around 5500 and the 35r around 4800. i think the 5500 is a little too laggy, but it can make closer to 700whp.
