spark plug problem???
Old Mar 11, 2008 | 11:30 AM
phat_bastage's Avatar
Originally Posted by wevo1
oh wow....learn something new every day....did u happen to see the recommended plug to get for the IX
I use the IKH24 Denso Iridum
These are a 1 stage colder plug.
You should do a search, you will not go wrong with OEM plugs, downside is they are like 19 bucks each.
Old Mar 11, 2008 | 03:18 PM
cssaddictm4's Avatar
Stock heat range for the EVO9 is a 7range plug. Should be gapped to .020-.022. Make sure you are using EVO9 plugs and not EVO8 plugs, they are not interchangeable.
Old Mar 11, 2008 | 05:00 PM
wevo1's Avatar
thanks alot guys!!
Old Mar 11, 2008 | 05:15 PM
CrackerJackToy's Avatar
Do you have a tune?
Maybe the gas sitting in the tank lost some of its points? Causing it to be **** gas, & causing your problems?
Old Mar 12, 2008 | 02:11 AM
Redline-Z's Avatar
Veteran: Air Force
YES, you can buy a box of 4 "one-step colder" plugs for a IX from ExtremePSI. Also stated above the general rule is 100whp = 1 step colder good luck!
I didn't have to gap my Iridiums but I did check them with a feeler gauge.
Old Mar 12, 2008 | 03:17 AM
smithc33's Avatar
Yeh i had the same problem with my evo 6. Just as the turbo started to kick in on full throttle my car missed and backfired. I took it to a mechanic who said the problem was definately the plugs and nothing else. He tried to get ngk platinum spark plugs without the resistor bit to give a better stronger spark as well as setting the gap right.
Old Mar 12, 2008 | 06:46 AM
evozakk's Avatar
I always check the gap before my plugs go in. Never assume. Gap for stock plugs I thought was .028-.030??
Old Mar 12, 2008 | 07:20 AM
Redline-Z's Avatar
Veteran: Air Force
The owners manual for my IX states .020 - .026
Old Mar 12, 2008 | 07:24 AM
evozakk's Avatar
^damn, I was looking at an 8.. next time I'll pay more attention.
Old Mar 12, 2008 | 08:25 AM
PVD04's Avatar
Put the stock wires back on. Do a search for Magnecor and you will find that tons of people have had problems with them.
-Paul
Old Mar 12, 2008 | 10:54 AM
Redline06's Avatar
Are the Denso Iridium IKH24 required to be gapped or could the be just dropped in??
Old Mar 12, 2008 | 11:01 AM
They claimed to be properly gapped. But I checked all of them just to be sure
I bought them from sparkplugs.com - You have to search directly for the model number, because only the IKH22s come up when you search by car.
Old Mar 12, 2008 | 12:51 PM
waitin4d's Avatar
I also put IKH24... Dropped right in.. Fixed my sputtering.
Old Mar 12, 2008 | 05:19 PM
edmundo's Avatar
Denso IKH22 is listed as the OEM equivalent for the IX
Old Mar 12, 2008 | 10:22 PM
el producto's Avatar
OEM plugs are good to 60,000 miles (says in manual)
I changed mine recently at 40,000 miles with the BRP7es and I think I also got like a boost flutter when I floored it under 3500rpms in a higher gear at slow speeds, but it went away and car has been running fine....
