Exedy HD Twin users - I need the installation diagram
Does anyone have the diagram that shows the order the plates go in? I removed this from my car and am needing to reinstall it and lost the installation sheet. Thanks.
I appreciate the reply, I don't believe that is for the twin plate though. I called their tech support and left a message several days ago and have not gotten a call back.
? not sure of this will answer the question but here goes,
Obviously the flywheel bolts to the engine, then the first disc goes in (it's labeled on the hub as such, with which side faces the engine), then the floater plate (it will be obvious which way it faces when it's in front of you), then the second disc (labeled on the hub also), and finally the fulcrum ring and pressure plate.
sponge bob
11
Feb 29, 2012 01:10 PM
RogueSTi
19
Mar 14, 2009 10:26 AM
