help with modification plans
Old Mar 12, 2008 | 06:38 PM
pitman's Avatar
built bottom end
atp 3071r
precision 720cc injectors
greddy type-m intercooler kit
hks twin power
walbro in-tank pump
power fc l-jetro
c-16 22psi
400whp/425 trq
plans;
megan racng exhaust mani
garret 35r (will swap exhaust housings with the 3071r so will direct fit and then sell 3071r)
water/meth injection
blox 272' cams with valve springs and retainers
hks cam gears.
will be tuned on 93 octane with 50:50mix meth:water
using the same tuner as above should i be able to achieve similar or more power than i did with old set-up and c16?
will the 35r be neccesary to achieve that power?and will it be much more laggy?
http://www.slowboyracing.com/estore/...at=4557&page=1
would this be the bext kit to use givven other modifications.
