Axle seal nightmare...
Old Mar 25, 2008 | 06:11 PM
BaLListic_EVO's Avatar
Anyone have any suggestions for an axle seal that is leaking. We reinstalled another seal and the leak is still there. I believe that the t-case may be slightly overfilled and im unsure if that would cause it to leak. Are there any tips for installing the seal to make sure it will not leak?
Old Mar 25, 2008 | 06:15 PM
Curt@MrLed's Avatar
Former Vendor
The axle may have a wear mark from the seal. Fix is a new axle.
Did you see if there was a wear ring there from the last seal.
Did you lightly sand the axle before reinstalling it too remove any imperfections.
Is it marred in any way.
Old Mar 25, 2008 | 06:16 PM
Did you see if there was a wear ring there.
Did you lightly sand the axle before reinstalling it to remove any inperfections. Is it marred in any way.
didnt really check but ill pop it back out this weekend and check. Ill try the sanding method see if that fixes the issue. There wasnt an issue till it was reinstalled after an engine install before that it worked perfect. We had also had the t-case serviced by a local company as well.... I assume that the seal that just went it will be fubar since its been on the old surface....
Old Mar 25, 2008 | 06:19 PM
w3rd's Avatar
This may sound really simple, but make sure the axle is pushed in all the way. I mean ALL the way. You could swear it's seated but by pushing it in a little bit more it will seal. It happened to me when i swapped my clutch.
Old Mar 25, 2008 | 06:21 PM
thanks for the tip but yeah its fully seated i have installed 4 clutches and 1 engine and never had this issue before......
Old Mar 25, 2008 | 06:22 PM
Curt@MrLed's Avatar
Former Vendor
Use a good fine grit. Around 900-1000. You dont want more scratches.
gsrboi80's Avatar
Same thing happened to me with my old Teg went through 3 seals before I figured out that the axle was the culprit. Its an easy job so I wasnt too mad
Old Mar 25, 2008 | 06:24 PM
yeah just seems odd that it would be the axle when it was fine prior to it coming out.... But the car did have a big blow up sending pieces of rod out the front and rear. I didnt see any marks on the axle that would indicate that it was struck by stuff flying but i guess its always possible....
Old Mar 25, 2008 | 06:25 PM
thank you sir we will get another seal and try this out this weekend...
Old Mar 25, 2008 | 06:33 PM
gsrboi80's Avatar
Yea man the one that leaked in my Teg was actually a aftermarket replacement cause the OEM was going. Put it in and next oil change I noticed the leak.
At that point I pulled the damn thing out thinking I damaged the seal. I checked out the axle and didnt see anything on the shaft so 2 seals later I replaced the axle and what do you know. No more leak
Old Mar 25, 2008 | 06:40 PM
wish you could just buy the cup.... as the axle is pretty expensive and there is nothing wrong with it. Ill try the sanding method first and pray that solves it. This isnt even on my car its a friends im just trying to sort it out..... Sucks to get done installing an engine and barely be able to drive the car over a leaky axle lol
Old Mar 26, 2008 | 02:37 PM
Ev0cRaZy's Avatar
Didnt know you made a thread lol
Thanks for the suggestions so far, please keep them coming.
Old Mar 27, 2008 | 08:53 AM
dryad001's Avatar
Should post pics Zach, that might help people to determine the cause. And you need to fix it quick, make a road trip out here.
Old Mar 27, 2008 | 11:03 AM
mithrandir7533's Avatar
Make sure you match the new axle against the old axle. I burned up a tranny on my 93 Integra GSR because I got teh wrong part. It seemed like it fit, but the shaft wasn't long enough to make the seal.
Old Mar 27, 2008 | 01:03 PM
Ev0cRaZy's Avatar
Thanks Mike, ill have to do that soon enough
