Exedy Twin HD
Old Apr 3, 2008 | 12:55 PM
k270kmh's Avatar
Exedy Twin HD
I'm ready to buy an Exedy Twin HD, but I could not find its weight anywhere.
I did a serach here and found out that the SD version is 29lbs, but what about the HD version? Is it heavier?
My stock clutch is 30lbs, so I do not want to go heavier.
Btw, the reason I'm changing the clutch is that I went to the wrong way with the Exedy twin CARBON, that is good ONLY when super HOT, a situation that you will not be during the street or road driving, just when drag racing or at the track.
Fo the Twin HD owners: How does it feel at the track? shifts good at 8k rpm?
Thank you
Old Apr 3, 2008 | 01:21 PM
TurboRSX04's Avatar
i was at the track last night it felt awesome. when it heats up it will grip harder. no lockouts for me and i had it for 7k so far. as for heavy i believe it is heavier than stock clutch.
Old Apr 3, 2008 | 01:42 PM
k270kmh's Avatar
I called Exedy some minutes ago and I was informormed that the SD and HD are the same weight. The total weight is 34,5lbs!!! too heavy!
Ok Is it 29 or 34lbs? ? ?
this link says it is 33lbs:
http://www.extrememotorsports.com/pr...4&cat=0&page=1
Old Apr 3, 2008 | 01:47 PM
k270kmh's Avatar
35lbs here:
http://www.fullfunction.net/product....tseller=Y&js=n
TTP Engineering's Avatar
They are 32lbs and we have them in stock. Your PM box is full -we responded to you.
Old Apr 3, 2008 | 01:50 PM
k270kmh's Avatar
Is there someone here that put this cluth on a scale? stock vs MM022HD? ? ?
Old Apr 3, 2008 | 01:54 PM
k270kmh's Avatar
Thanks TTP!
Old Apr 3, 2008 | 04:10 PM
k270kmh's Avatar
28lbs here:
https://www.evolutionm.net/forums/sh...t=exedy+weight
Old Apr 3, 2008 | 04:12 PM
k270kmh's Avatar
29lbs here:
https://www.evolutionm.net/forums/sh...dy+twin+weight
Old Apr 3, 2008 | 04:22 PM
Wicked E's Avatar
Mine is brand-new in the box... Let me weigh it and lay this topic to rest...
Edit: 32.4 via my very accurate scale. This is what TTP said, I am guessing the .4lbs is due to the TOB?
Cheers-
E
Old Apr 3, 2008 | 04:40 PM
k270kmh's Avatar
Thanks Wicked E!!!
Old Apr 3, 2008 | 05:53 PM
k270kmh's Avatar
It seems that the Ralliart TWIN RACP9201S1 is 29,7lbs or 13,4Kg:
http://www.chiptuning-wolf.ch/data/Katalog%20Evo.pdf
weird because exedy twin and ralliart should weigh the same
btw, there is a super light version of the ralliart twin that is 10,5Kg
Old Apr 3, 2008 | 06:03 PM
I think getting hung up on the weight of the unit is misleading. The weight and circumference of the discs themselves are more important than the clutch's weight as the discs are what are connected to the input shaft..
Old Apr 4, 2008 | 07:34 AM
k270kmh's Avatar
Answer from Exedy Japan
Dear. Mr....
Thank you for your inquiry!
Net Weight of your inquired clutch is as follows,
Stock No. Net Weight
MM022SD 13.24kg/pc
MM022HD 13.24kg/pc
thanks and regards.
EXEDY Co.,Ltd.
Tateno
info@exedy.co.jp ??: 2008/04/04 08:17:47
?? : info/EXEDY@EXEDY
cc :
?? : Inquiry : Exedy Twin WEIGHT
Old Apr 4, 2008 | 02:01 PM
k270kmh's Avatar
Called Exedy USA again, they told me that 34,5lbs is with box and 29,6lbs net!!!
