Clean My Pistons????
Old Apr 9, 2008 | 04:38 PM
CO_VR4's Avatar
Assuming you're not planning to completely change your fuel there is a product that is well tested to remove the deposits you're seeing. It's called Mopar Combustion Chamber cleaner. You can buy it at any Dodge or Chrysler dealer. Google it and you'll find lots of DSM references for it.
Also can be used with the head on the car, for those of you who are curious.
Old Apr 9, 2008 | 04:48 PM
justboosted02's Avatar
Seafoam
Old Apr 9, 2008 | 10:03 PM
dxbevo9's Avatar
Originally Posted by JordanS4
cleaning them won't do much, put pour some new motor oil on them and scrub them with a rag or brillo pad. it won't get it all off unless you go at it for a while but it will help. this is how i was advised to do it by Nick @ DTM. He and I both qualify as "people with experience", although mine is much less.
p.s. probably moving to dubai in june!
hey Jordan...
let me know when you get here!! are you planning on bringing the evo with you?
Old Apr 9, 2008 | 10:05 PM
dxbevo9's Avatar
Originally Posted by TTP Engineering
Run methanol injection. Problem solved!
We have kits in stock Moosa!
hahaha scott!!
i do not like anything but pump...especially meth coz no one knows how to set it up properly here...4Wheel Slide might be coming to dubai soon i know he has a lot of experience with meth..i might ask him to get me a kit with him to see what he can do!
thanks for the suggestion though..you might be hearing from me soon
Old Apr 9, 2008 | 10:06 PM
dxbevo9's Avatar
everyone else....thhhhhaaaaaaaaaaaaaaaanks!!
Old Apr 10, 2008 | 06:55 AM
LilRico's Avatar
LOL for meth suggestions....
I remember when I took my head off, I just used clean motor oil and a rag and it came right off. I didn't need to scrap, scratch or anything, they just cleaned and shined like new.
Old Apr 10, 2008 | 06:48 PM
JordanS4's Avatar
Originally Posted by dxbevo9
hey Jordan...
yes i am planning on it. dad got the job with nakheel maybe he will be working with you
Old Jun 17, 2008 | 05:33 PM
MasterAK's Avatar
Do I have to replace the spark plugs after running the seafoam through the vacuum hose?
Old Jun 17, 2008 | 05:56 PM
mchuang's Avatar
Leave the carbon deposit, proven hp from higher compression haahahha
Old Jun 18, 2008 | 08:27 PM
PharmEcis's Avatar
LOL
Much less? I don't even think they make a fraction that small!
Most of that carbon won't clean up very much unless you put some serious elbow grease into it. Make sure if you use some kind of chemical cleaner to flush whatever is in your oil pan before startup.
Old Jun 18, 2008 | 08:33 PM
2theMAX's Avatar
Please don't use that stuff.
Old Jun 18, 2008 | 08:39 PM
DRFTKNGG's Avatar
perfectly normal, leave it as is. Cleaning them will not do anything for you.
Old Jun 18, 2008 | 08:59 PM
why not? seafoam is hours of entertainment
Old Jun 18, 2008 | 10:33 PM
BluEVOIX's Avatar
Use brake dust cleaner to clean the top of the pistons.
Old Jun 18, 2008 | 10:42 PM
cpoevo's Avatar
cleaning the carbon build up on the pistons can help the car perform better. The reason being is the carbon creates "hot spots" which can cause preignition.
