First time changing TC fluid.
Old Apr 10, 2008 | 02:49 PM
ak47po's Avatar
Question First time changing TC fluid.
When changing TC fluid other than draining and refilling is there anything else involved.I noticed the bleeder for the ACD on the bottom of the TC.Do i have to bleed the ACD when just changing the TC fluid?I know they are two different types of fluids.This is the first time changing TC fluid so im not sure of the process.
Old Apr 10, 2008 | 03:14 PM
lemmonhead's Avatar
the mitsubishi tech manual says when they changed fluids they use their special tool to pump out all the fluid. If i were you, i would just let mitsu do it. cost more but at least you know all the old fluid will be out. otherwise your just relying on gravity to get as much out as possible.
Old Apr 10, 2008 | 03:33 PM
ak47po's Avatar
This is what i have to go buy.
All i need to know is do i stop after refilling TC,or do you need to bleed also.
Old Apr 10, 2008 | 03:48 PM
lemmonhead's Avatar
see it says you "forced" fluid out using that tool, that is what im talking about. That was enough to not wanna do it myself.
