Test pipe question
Old Apr 23, 2008 | 05:51 AM
strtrcng426's Avatar
Test pipe question
Hey guys i just picked up a evo 8 and the car has a downpipe with a hks carbon ti exhaust. I was wondering what the test pipe does ?? would it make my car louder ??
thanks
sakib
Old Apr 23, 2008 | 05:59 AM
Ambiguous's Avatar
I believe most test pipes will bolt right up, except the ams, because it has a 3 bolt flange i believe. It will def. make your car louder!
Old Apr 23, 2008 | 06:01 AM
Does the test pipe take away the resignator ??
Old Apr 23, 2008 | 06:06 AM
EvoHung's Avatar
You mean the resonator? The resonator is usually in the cat-back part of the exhaust so it depends on the exhaust. Also, some test pipes comes with a resonator. In general, the test pipe will replace the cat-convertor
Old Apr 23, 2008 | 06:16 AM
Burklow's Avatar
Test pipe is used for removing the cat. Why would we want to do this? On a N/A car, a cat isn't a big restriction at all in the exhaust. Removing usually results in a couple of WHP, but nothing big.
On a turbo car, the cat is a HUGE restriction. Removing the factory one and going to a test pipe will gain anywhere between 10-30 WHP depending on a few things. For a cheap, flanged piece of pipe, that's amazing value for power. My test pipe is resonated, so it is a bit quieter <3K RPMs, but it is VERY loud at WOT. You'll get an increase in boost too with any test pipe. On my car with only a Megan TBE, I went from 19.5 PSI on the gauge to 21 PSI after install. I turned it back after I installed an MBC.
[Side story: I had a friend drive around the neighbourhood in my car while I listened outside. I could hear every pull he did, some 1/4 to 1/2 mile away. Having a test pipe makes me drive slower because I know how loud it is outside. In the cabin, it doesn't sound much louder than just a catback.]
I highly suggest getting a test pipe if you want the most power from the exhaust. Be warned! They aren't exactly legal, it will trip a CEL if you don't space out the rear O2 sensor with a 1/2" drilled 18mm non-fouler, and now my car smells like a go-kart. I've had police follow right behind me without any problems, but anyone can definitely smell it. You can PM me if you have any questions.
Old Apr 23, 2008 | 06:33 AM
El.BlueEvo9's Avatar
thanks
sakib
It'll make your car scream when you get on it, but hey now, Test Pipes Are For Off Road Use Only.
Old Apr 23, 2008 | 06:36 AM
Evo Tengoku's Avatar
Test pipes make your car stink.
Old Apr 23, 2008 | 06:37 AM
No Dion.......it makes your car stink
Old Apr 23, 2008 | 06:39 AM
gmore84's Avatar
[QUOTE=Burklow;5577998]Test pipe is used for removing the cat. Why would we want to do this? On a N/A car, a cat isn't a big restriction at all in the exhaust. Removing usually results in a couple of WHP, but nothing big.
Yeah, it added 22horses to my friends car on a dyno with a high flow cat vs a test pipe.. so, he decided to leave the test pipe on.. power is power and get where you can right?
Old Apr 23, 2008 | 09:58 AM
BBS's Avatar
BBS
Did you completely miss the newb section? There are tons of threads there about exhaust components.
Old Apr 23, 2008 | 10:07 AM
DoughtCom's Avatar
Jeez a HFC vs a test pipe is that big of a diff? Makes me want to get rid of my HFC
I say this a day after "Earth Day" heh
Old Apr 23, 2008 | 10:30 AM
lemmonhead's Avatar
WARNING**** EPA (enviromental protection agency) can fine you $2000 or more for not having the catalytic convertor on your car.
just someting to keep in mind, definetly dont bring the car to the dealership with a test pipe on, by law they have to report you to the agency or loose their business license.
Old Apr 23, 2008 | 10:32 AM
EvoHung's Avatar
Oh your rear bumper will turn black near the exhaust too.
Old Apr 23, 2008 | 10:34 AM
bluebanana23's Avatar
Get a hi-flow cat and be done with it. 10whp is not worth the environment.
Old Apr 23, 2008 | 06:49 PM
Dipz's Avatar
Phew. Good thing I live in Florida, where discriminating against a poor man's vehicle condition is grounds for violating personal Amendments
