03 EVO 8 spark plugs
Old Apr 23, 2008 | 01:12 PM
KtownEVO8's Avatar
I recently purchased an o3 Evo 8 and need to change the spark plugs, but i am not sure which ones to get. I have seen many arguments for and aginst iridium as well as copper, and different heat range, i would like to go ngk. It has aftermarket cams, TBE, EBC, what do you think is best.
Old Apr 23, 2008 | 01:50 PM
wshihdnevo's Avatar
ngk bpr7es or br7es
part #: 2023
You can find them at schucks for $1.99 each. I always gap to .022 I run around 25 psi on 92 octane.
Old Apr 23, 2008 | 05:35 PM
evo150's Avatar
Originally Posted by wshihdnevo
ngk bpr7es or br7es
part #: 2023
+1 for ngk bpr7es or br7es....... i keep mine gapped at .026
Old Apr 23, 2008 | 05:39 PM
wshihdnevo's Avatar
^how much boost you running? I would go down atleast to .024
Old Apr 23, 2008 | 06:32 PM
itsme4g63's Avatar
bpr7es should come pregapped, drop in and drive.
Old Apr 23, 2008 | 06:33 PM
SpyderTB's Avatar
ngk bpr7es or br7es
part #: 2023
I just went through buying plugs for my 03 evo i just bought and i just picked up 16 of them . . . i like to have stock.
Old Apr 23, 2008 | 06:38 PM
wshihdnevo's Avatar
more like check them, regap and then drop in...
Old Apr 23, 2008 | 06:54 PM
gotboostawd's Avatar
so then with a all around stock car would that be the same suggestion for spark plugs....or any different since there isnt anything done yet....
what about gapping the plugs running stock boost now and maybe bumping it up sometime soon?
Old Apr 23, 2008 | 07:17 PM
wshihdnevo's Avatar
^id say run the bpr7es's at .024 at stock boost.
Old Apr 23, 2008 | 07:20 PM
word.....thanks....
then what you do think adjust gap once the boost increases?
Old Apr 23, 2008 | 07:33 PM
wshihdnevo's Avatar
yes, .022 at 25+ psi has been good for me. I change my plugs every oil change, cause they are so cheap.
Old Apr 23, 2008 | 07:34 PM
itsme4g63's Avatar
Aye, wish I could do that with mine, damned evo9's.
Old Apr 23, 2008 | 07:35 PM
wshihdnevo's Avatar
^yeah, but you got mivec, so i think we're even
once again thanks
im sure i will be thanking you all more and more as time comes
Old Apr 23, 2008 | 07:38 PM
itsme4g63's Avatar
more s-hite to break
