some boost Q
Old Apr 24, 2008 | 08:28 AM
evovickers's Avatar
some boost Q
ok 2 months ago I bought a auto meter boost gauge at full boost I would get about 21psi. i ran it like that for about a week or two. I bought a header, turbo outlet, and down pipe. for the test drive I got on it and I could only get about 15-16 psi I made sure every thing was hooked up right and test drove it once more. same thing the pull of the car felt a little faster. a week later i put my mbc in. it was a Hillman with the light spring ( i didn’t know at the time that with the mbc turned up all the way with the light spring would still not change the boost.) but right away it was right back to regular 21 psi i have not pushed it since just in case some thing is wrong. can some one help me with this problem
Old Apr 24, 2008 | 08:33 AM
TeStUdO's Avatar
Do you have a tune at all? If you turn your boost controller all the way down, you should be boosting at wastegate pressure.
Old Apr 24, 2008 | 08:54 AM
evovickers's Avatar
i dont have i tune but u would think that the boost would stay the same with a new header and outlet and dowm pipe
Old Apr 24, 2008 | 08:56 AM
TeStUdO's Avatar
With no tune, turn down your boost with your MBC to ~18psi. As long as your MBC works now, you're fine.
Old Apr 24, 2008 | 09:06 AM
evovickers's Avatar
i was just wondering why i would drop 8 psi just becouse of a header and outlet. when i turn it all the way down it goes to 21.. my gauge could be off tho that is waht it was doing befor i put in the stuf
Old Apr 24, 2008 | 09:11 AM
TeStUdO's Avatar
Turn your boost all the way down and try another gauge. If you arent seeing 12-15lbs, then you hooked up your MBC wrong.
Old Apr 24, 2008 | 09:17 AM
evovickers's Avatar
ok i will try that if i can find another gauge. how much boots can you run on 91?
Old Apr 24, 2008 | 09:20 AM
TeStUdO's Avatar
I wouldn't run more than 18 on 91 with no tune.
Old Apr 24, 2008 | 09:23 AM
dpacific's Avatar
19 psi is stock.
turn your MBC all the way down and make sure you read 11psi (waste gate pressure)
Old Apr 24, 2008 | 05:13 PM
evovickers's Avatar
ok i turned it all the way down and i just stays at 21 ( its what my gauge says dosent me its not 19 cuz that is what it was befor i put the mbc in) i dont think i hooked it up backwords >>>http://www.hallmanboostcontroller.com/howto.html<<<
thats how it is hooked up
bboy_RES
32
Jun 18, 2009 02:26 PM
drewblueeye
Aug 30, 2007 07:33 AM
justchil
94
May 5, 2007 07:13 PM
QuickEvo
15
Oct 26, 2005 03:38 PM
scottatyamaha
16
Feb 28, 2004 07:34 AM
