s3's on a stock turbo 9
Old May 8, 2008 | 09:47 PM
  #46
wshihdnevo's Avatar
Originally Posted by Sky Evo X
The tq on Chris' car is "short" on torque buddy.
haha...
Old May 8, 2008 | 09:48 PM
  #47
wshihdnevo's Avatar
Originally Posted by tien
are the cammed evo9 sound lopey as the 8's? sorry for OT, just curious
- Tien
They can if you want them too...
Old May 8, 2008 | 10:10 PM
  #48
hanahawaiian's Avatar
ill redyno after fix WGA arm.. see how much imporve... then ill add TB 65mm and ported intake
Old May 9, 2008 | 08:23 AM
  #49
GregGSC's Avatar
Originally Posted by dbsears
Ohhh are these R1's for evo IX applications? They look to be a tad more aggressive over the S1's. Hows the idle on those R1's with the added lift & duration? I wouldn't mind something a tad more than the S1's.
Also seems like everyone got thier answer on the S3's.
R is for RACE only.. meaning idle, running on a stock ecu or stock valvetrain/head was not our goal... these are for making big power for those that are willing to push it to the limits...
also these will all be solid lifter profiles... meaning running them on a Hydralic lifter will not net you the power of the S series...
these are suggest to be run on our GSC cylinder head as we have designed them around the flow and velocity of the ports.
we will be releasing solid lifters that use shims for these.
yes paul i'll be taking a trip to WA to put a set in ur turd... cuse no one out there wants to install solid lifters...
I will be offering something for the 9 guys if there is any demand i'll cook something up. just not a shelf item.
Old May 9, 2008 | 08:56 AM
  #50
JohnBradley's Avatar
Interesting tech Greg and Martin.
I knew that the compression bleed off might not be offset by the airflow from a stock turbo but I had been thinking that with a high compression bottom end it might not be too bad.
aaron@englishracing.net
Old May 9, 2008 | 10:30 AM
  #51
GregGSC's Avatar
Aaron, you are also correct but when you say high compression it should be something in the 10+ range. you will want longer duration on the exhaust side.
Old May 9, 2008 | 10:43 AM
  #52
Paul Nelson's Avatar
My Turd!!! Bah you can do all the maintenance of solid lifters As soon as you get up here im taking you to Team Quest to help you with those extra punds you keep *****en about
Old May 9, 2008 | 04:44 PM
  #53
Most-Wanted's Avatar
- Tien
The answer is yes to the lopey idle, maybe a little more subtle than the 8's. The big cams in my stock turbo car made 35 more wtq over the smaller S1's. I did make a few other changes like 65mm TB and ported intake. But since we are talking about modding and getting the most out of the stock turbo, I would assume you'd do these other items as well. It all works together. Can't just throw the biggest turbo on the car and expect it to be fast with out supporting mods. Same applies here.
Idle w/ 280/272
http://videos.streetfire.net/video/I...ams_159783.htm
Old May 9, 2008 | 04:51 PM
  #54
moses evo's Avatar
Originally Posted by JohnBradley
GSC is underrating the potential of the cams. There has already been more than one thread about running S2's on a stock turbo, both in the VIII and the IX and no one has loss power. Lucas runs S2s in his motor on a stock turbo and made 506whp and runs 127 in the 1/4 so far.
I run the S2s in my IX and not only do the idle fine, they pull VERY hard with the Green.
hi buddy we tested the 280 hydraulic s3s on a 2 litre car using a gt35r on norris designs dyno , it lost over 40 bhp at low revs but woz very good at high revs and kept its power and woz better than the s2s up at the high revs, s2 is the overall best performer for fp green onwards and simon did say the s3 will be better on a stroker kit though and wont lost power but will be better overall than an s2 using a gt35r on a 2.3 or 2.4 but def not on a 2 litre engine
when i have time im gonna test an s2 exhaust and an s3 intake and we might have the ultimate combo, u never know
Old May 9, 2008 | 05:08 PM
  #55
wshihdnevo's Avatar
That combo on a IX w/ a BIG turbo would be interesting to see as the cosi m3's are a staggered 280/272 combo. But also on an VIII would be nice to see though.
Old May 9, 2008 | 05:22 PM
  #56
SpooksEvo's Avatar
^^sounds like a plan to me
Old May 10, 2008 | 09:46 AM
  #57
FathouseFab's Avatar
Idle w/ 280/272
Man that car sounds sick.
You would not happen to have a dyno chart overlay to compare the m3's vs the s1's would ya.
Fathouse
Old May 10, 2008 | 12:41 PM
  #58
Fathouse
Actually I do, but I'll have to scan them and get them up. I had a faulty WGA so the spool up time was later, but since we fixed it, it feels like a different animal. I may put it back up on the dyno just to see. But I will post them next week if you want.
Old May 10, 2008 | 01:30 PM
  #59
Ya, that would be great. Cams are in my next round of mods, and there are to many choices for me. lol
Fathouse
Old May 11, 2008 | 11:03 AM
  #60
Brian's Avatar
Fathouse
OH no, who let you on this forum!
