Clutch Slave Cylinder
Old May 9, 2008 | 08:50 PM
rodrig.diaz3's Avatar
Whera i can buy The OEM Clutch Slave Cylinder For my Evo IX ???
I hope not from the dealer im looking from some Store.
Regards.
Old May 9, 2008 | 08:56 PM
Evoryder's Avatar
got one from a 2003 evo w/ 45k on it. Let me know ...what happend to your slave?
Old May 9, 2008 | 08:58 PM
the pedal dont return, i think is the slave, im loosing liquid ill check on monday and let you know.
regards.
Old May 9, 2008 | 10:21 PM
Evoryder's Avatar
I have a good master cylinder too. i had a clutch issue and wasted money and bought brand new slave +master...check to see if your master is leaking.
Old May 10, 2008 | 09:51 AM
dieselmd's Avatar
Slave cylinder
Regards.
JNZ Tuning.
Old May 10, 2008 | 10:50 AM
PPI's Avatar
PPI
I tried to use one that a customer gave me that he bought from the auto parts store...gave me nothing but problems and had horrible engagement and pedal pressure. Either way I would suggest to use a o.e. Mitsu one.
Old May 10, 2008 | 06:26 PM
Where I can Find the oem Master Cylinder?
Old May 10, 2008 | 06:35 PM
Evoryder's Avatar
dealership
mitsuparts.net
evoryder = me ...let me know
Old May 10, 2008 | 07:21 PM
dealership
mitsuparts.net
ok let me Check and i let you know.
Regards.
Old May 10, 2008 | 08:29 PM
Zeus's Avatar
First, fix your "leak" and re-bleed it. It WILL go to the floor and stay there until it has the enough fluid not to do so. Push it down, then pull it up until it stays on it's own. If properly bled, you MAY not need any new parts.
Hope you have already checked that the TOB is properly engaged...
Old May 10, 2008 | 09:12 PM
Good point, how can i check if the TOB is Engagged??'
thanks for your help.
