Making 380WHP with $635
Old May 16, 2008 | 05:39 PM
  #211
evosean's Avatar
wow, i just read all 210 posts... can i have that hour of my life back please???
Old May 16, 2008 | 05:47 PM
  #212
TURBODAWG's Avatar
Originally Posted by Mr. Evo IX
Vehicle weight with driver maybe. Did anyone log the car in EvoScan while it was run on the dyno? We can just run it through DLL if someone did.
He did run Evoscan on all the runs. Contact Blowoffsilver to get you a log. He may have deleted them after he tuned the cars though. Maybe not.
The EVC 6 is what was used in that video that showed no taper. I wrote an HKS Supplemental manual that shows how to set the EVC 6 to work and shows how to eliminate taper or customize the boost curve however you like it. You can make it run 16 psi and then taper up to 22 psi if you like with my manual. I have sold about 15 manual in the US and a few internationally. Everyone likes the manual and has the thing setup and taper free in about 10 minutes.
Brian
Old May 16, 2008 | 06:31 PM
  #213
Reth IX MR's Avatar
I can't believe I read all this. mx4life85, I think blowoffsilver should give you a complimentary dyno run. That's the only way to find out. Good Luck!
Old May 16, 2008 | 08:31 PM
  #214
mx4life85's Avatar
Its not his dyno. All he did was show up and tune my car.
Old May 16, 2008 | 08:37 PM
  #215
Mr. Evo IX's Avatar
Blowoffsilver, can you post the log so we can run a DLL whp/tq calc on it.
If you want to you could delete the contents of the igntion timing column and the wideband column if you feel that is proprietory information to your tune.
Old May 16, 2008 | 09:39 PM
  #216
blowoffsilver's Avatar
Man I just checked my logs and I deleted all but the last car, it takes way to much time to go through all the logs!! I had alot considering we put over 7 cars on the dyno. But if i still had it i would post it!! Sorry man.
Old May 16, 2008 | 09:48 PM
  #217
PedroMartinez's Avatar
Hey im going to support kasey on this. Kasey has tuned my car before and he is a good tuner. I have read all 15 pages about this thread. and i just think that ppl are flaming the tuner and dyno. Well I think i still have my stock dyno sheets when I first dynoed my car at this dyno. My car is an 03 Evo 8 N IT WAS BONE STOCK and i believe it made 266awhp imma have to go back and find my sheets. So i think the tuner did a very good job, no one should be running down his throat. Like mx4life said all he did was show up n do the tune.
I think its the dyno that the car was placed on as I know my car bone stock read pretty high as being a bone stock VIII.
Old May 17, 2008 | 06:00 AM
  #218
Ev0cRaZy's Avatar
What part of its not his dyno and he showed up to tune cars did you not understand?
Old May 17, 2008 | 12:38 PM
  #219
urslo4n8's Avatar
Originally Posted by mcwop23
let me introduce you to the first 14 pages of the thread
NO thank you.
Old Jul 3, 2008 | 08:23 PM
  #220
LpBevoEvo's Avatar
Originally Posted by mx4life85
HKS EVC 6.
Under what settings do you have to run it to hold steady like that?
thanks
Old Jul 3, 2008 | 10:05 PM
  #221
Jeff_Jeske's Avatar
I just want to see trap speeds.......
Old Jul 3, 2008 | 11:43 PM
  #222
importjake00's Avatar
crazy numbers.. ur car is on staroids
Old Jul 3, 2008 | 11:57 PM
  #223
Warrtalon's Avatar
No, the dyno reads very high. 03s with 266whp stock, and IXs with 280-290? Highest reading dyno evAr.
Old Jul 4, 2008 | 09:33 AM
  #224
Originally Posted by dsmfan95
On the same dyno I was going 91/115mph with 366whp in an SSL Evo. That clutch won't last long though if launched some.
huh??? wow not the much higher!
Old Aug 1, 2008 | 01:03 AM
  #225
Shocky's Avatar
wow great numbers!!
