Vent to atmosphere?
Old May 16, 2008 | 07:32 PM
crazyndn49's Avatar
Vent to atmosphere?
I'm wondering on a stock IX MR if a BOV can be vented to atmosphere as opposed to being recirculated, and if it can will it cause any problems with drivability/reliability? Once I get a good answer, you guys can delete and make more space for something more important.
Old May 16, 2008 | 07:38 PM
STiHAVOK's Avatar
have you tried a search?
Old May 16, 2008 | 07:40 PM
Smike's Avatar
Please search VTA.
No you cannot do VTA.
Old May 16, 2008 | 08:39 PM
Warrtalon's Avatar
Drives: Dodge SRT-4
No surprise. Please use the newbie forum AND search before making another thread in one of the real tech forums.
Old May 16, 2008 | 10:18 PM
IDRNKV8's Avatar
Answer: DV. Very basic, wouldve taken u 10 min to find if u wouldve searched
Old May 16, 2008 | 10:34 PM
8UpUrV8's Avatar
I'm running a blowthru maf setup on my 240 with a vented IX bov, haven't put many miles on it yet though.
...not that it matters
Old May 16, 2008 | 11:01 PM
BluEVOIX's Avatar
Its a little difficult to understand what exactly you are trying to do because you ask a question about an Evo BOV but yet you drive an SRT-4....
For an EVO: You can physically setup the Diverter Valve to blow off to the atmosphere and not recirculate but you will cause a small problem. The ecu is programmed to recirculate that air and there for enriches the a/f ratio. If you vent the pressure to atmosphere, the ecu will still dump in the extra fuel thinking the air was recirculated. And this will cause problems with how the motor runs.
You can get a tune to blow it off to the atmosphere. So to make things short, it is mechanically possible, but the stock ecu program it is not recommended.
Now if you wanted to hook it up to the srt-4 and use it on that car, then I believe it is duable as long as you have the correct flange or weld it on.
X-rated
Cobb AccessPORT
Aug 29, 2017 10:13 PM
kapolani
Nov 30, 2016 06:00 PM
turbo26tsi
30
Jun 6, 2011 09:07 PM
Shaun@AWDMotorsports
16
Nov 23, 2007 10:06 PM
nonmature
Dec 20, 2003 01:24 AM
