Low Hp Need Help.!
Old May 17, 2008 | 11:18 AM
caixlim's Avatar
Unhappy Low Hp Need Help.!
I Have A 2003 Evo 8 With The Following Mods:
Invidia Turboback Exhaust W/ Test Pipe
Injen Intake W Full Piping
Walboro Fuel Pump
Invidia Exhaust Manifold
Turbo Xs Mbc
Ok So I Just Took My Car To Get A Dynotune W Reflash And The Numbers Are Making Only 250.9 Whp @ 22psi On Stock Turbo.!!! The Shop That It Took It To Told Me That The Invidia Manifold Was Causing The Loss Of Hp And That I Need A Bigger Turbo. Is This True.? Will A 20g 10.5 Help.? What All Would You Guys Recommend I Add To Make Larger Numbers That I Am Making Now.?
Old May 17, 2008 | 11:23 AM
alloutDSM's Avatar
what kind of dyno was it?
Old May 17, 2008 | 11:25 AM
scottatyamaha's Avatar
This is key info we need to know.
Old May 17, 2008 | 11:27 AM
caixlim's Avatar
the dyno sheet says awd dyno dynamics dynamometer
Old May 17, 2008 | 11:33 AM
alloutDSM's Avatar
this sounds like a bad tune, even on a DD, that manifold should be fine all its doing is allowing better flow i never heard of getting less HP because a manifold?
Old Jun 22, 2008 | 04:48 PM
TTP Engineering's Avatar
Glad we could help today. The car baselined at 251whp on our Mustang Dyno and left with 335.6whp.
When you invest in the right shop with the right know-how, you get the right results.
Congrats on your +86whp TTP-Engineering dynotune.
Old Jun 22, 2008 | 05:11 PM
importjake00's Avatar
^^^^ very nice
