next step for more power in my 8
Old May 18, 2008 | 02:51 AM
hiphopfeinds's Avatar
current mods: evo 9 turbo, 255 fuel pump, testpipe, mbc, o2 housing, tuned at 22 psi
i was wanting around 400 hp which i know is possible on the stock turbo but i dont know if thats pushing it. just want some opions on diffent upgrade paths
Old May 18, 2008 | 04:46 AM
Evo8Emperor's Avatar
Buy a nice Labonte Meth Kit from 4WS and get a wideband and he'd be more than happy to get you to 400whp.
You probably might want to upgrade your injectors also. They should be fine especially since your going to be injecting meth as more fuel but good to be on safe side.
That and some arp head studs you'll be good to go.
Old May 20, 2008 | 02:53 AM
i already have a wideband and a jdm evo 9 dv too btw and im kindda iffy about runnin meth........
Old May 20, 2008 | 02:56 AM
nemosEVO's Avatar
Just make sure its a habbit to check it, other than that its not like Nitrous.
Old May 20, 2008 | 04:07 AM
cfdfireman1's Avatar
"iffy about runnin meth........"
Then use nothing but c16 and you can avoid meth.
Old May 20, 2008 | 05:36 AM
turbo271's Avatar
C16 is too $$$$
go E85
Old May 20, 2008 | 06:40 AM
And bring a 55 gal drum of that E85 with if you ever do a track day.
Old May 20, 2008 | 06:41 AM
BocaShula's Avatar
forget all that... PUMP it
Old May 20, 2008 | 07:01 AM
Aby@MIL.SPEC's Avatar
looks like you are missing some cams from your mod list.....gsc s1 cams are a great all around cam.
Old May 20, 2008 | 11:07 AM
LoKiEvo's Avatar
there are many ways to make 400hp without meth. You need to help the car breathe better. I recomend Buschur Parts but I am biased. Anyways get the exhaust manifold ported (unless you are going with a bigger turbo you wont benefit from a tubular), o2 housing ported, turbo echaust housing ported, 3" turboback exhaust, upgrade the intercooler and piping, 272 cams (best size cams for stock turbo), a good tune and you should be able to make 400hp. If you want to push it a little more get the intake manifold ported and a 65mm throttle body. Like I said I prefer buschur, here is a setup that my buddy has:
EVO 8:
-RS TME 16g Turbo (w/10.5cm Ported Housing)
-BR Ported Exhaust Manifold
-BR Ported o2 Housing
-BR 3" Turboback Exhaust w/ Magnaflow Muffler
-BR Mass Air Pipe w/ K&N Filter
-BR Race FMIC
-BR 2.5" LICP & UICP
-Tial BOV
-BR Inline MBC
-BR 65mm TB
-BR Ported Intake Manifold
-BR Springs and Retainers
-HKS 272 Cams
-AEM EMS
-EXEDY Sigle Carbon Clutch
He made 447whp/406ftlbs at 23psi on 93 octane
Ran an 11.78 @ 121mph
Old May 20, 2008 | 01:05 PM
RevMoto's Avatar
I can tell you right now you aren't going to break 400awhp on pump. Like stated before go with s1's and meth. Meth is safe with a quality kit.
Old May 20, 2008 | 02:21 PM
Ph3n1x's Avatar
Even Green on pump and supporting mods and you will see 400WHP, 93 and 91 octane though.
Old May 20, 2008 | 05:51 PM
meth it
plus1^
It's going to be tough on a stock VIII not having the Mivec even with a IX turbo. Problem with E85 is in most areas you're going to have to hunt to find it. I think cams would be a BIG help to get you to your goal.
Old May 20, 2008 | 06:00 PM
grillpt's Avatar
I had basically the same mods as you minus the o2. I recently installed a set of HKS 264's (I went with them because I wanted more torque then top end) and couldn't be happier... The car made 297whp and 310lb-ft @ CBRD.
Get a set of cams, you'll be glad you did.
Old May 20, 2008 | 07:00 PM
297whp is close to 400 how? and by the way it takes torque to make HP.
