50 trim only able to hold 23psi to redline?
Old May 27, 2008 | 06:01 AM
paintballproam's Avatar
I cant get my 50 trim to hold more than 23psi. It gets up to about 28psi (im running meth) and then drops down to 22-23psi at redline. Its a stock head, with a 264/272 cam setup. Im really thinking i have a boost leak, but i need to get ahold of a boost leak tester.
Old May 27, 2008 | 06:06 AM
xxNosTankxx's Avatar
What kind of wastegate/ BC Setup do you have
Old May 27, 2008 | 06:16 AM
Tial 44mm wastegate, and an AEM Tru-Boost
Old May 27, 2008 | 06:22 AM
BiFfMaN's Avatar
yah boost leak test first
But could be a group of things at that boost level. plus its not uncommon for a diverter valve to leak too...mine has leaked past the 25 psi mark also.
Old May 28, 2008 | 04:35 PM
EMonz57's Avatar
Aaron that BOV will leak past like 24|25PSI. He has the APS duel vent.
If you search you can find a few threads of how people used teflon tape to fix the leak and then they valve would hold 30-31PSI.
Its prob that for sure
Old May 28, 2008 | 04:42 PM
Randy's Avatar
Check your Wastegate springs as well ......
If you have a smaller spring inside it wont hold as much boost til redline.
Old May 28, 2008 | 05:21 PM
EMonz57's Avatar
^^ he has a TiaL 44mm gate that has like 6k on it. There is no reason the gate would be the issue IMO. I am putting money on the APS duel port being the issue
Old May 28, 2008 | 07:16 PM
Randy's Avatar
Doesnt matter how many miles he has on it, I am talking about what color spring he has in the gate. If he doesnt have a big blue spring or something similar via 2 springs (big & small) he wont be able to hold more than that. I had a 50trim with a 44mm wastagate, I changed springs and all that was fixed. Its all in the owners choice, I used 2 blue springs and it DID help with the boost being held more consistently. Also those APS have some adjusting properties if Im not mistaken, I've seen 500whp cars using it no problems and trapping over 135mph.
Old May 28, 2008 | 07:40 PM
CrackerJackToy's Avatar
Doesnt mean he may have a faulty one.
Start with whats easy, buy a Forge Diverter, drop in the red spring & never worry about it again.
Old May 28, 2008 | 09:59 PM
staatz's Avatar
Or get a Tial
Old May 29, 2008 | 06:07 AM
EMonz57's Avatar
Well I still say its not the gate. this kit was used on a 2.3L turbotrix motor running meth and was making 476/474 for a while a little bit of time before it went into this car.
I still say it is the BOV. there is no need to sell it and buy a new one either Aaron there are Fixes for a leaky APS duel port valve to make them hold up near 30PSI. the factory state of the aps it WILL leak after 24PSI. But there are many people using them in higher HP cars because they teflon tape the inner side of the vac nipple and it prevents the leak at that point till around 30--31PSI so that is how HIgher HP guys use them still. Like I said Aaron just search around about the leaky APS fix threads and youll find it and beable to atleast rule the BOV out (most likely fix your leak too)
Old May 29, 2008 | 06:17 AM
zbomb's Avatar
Boost leak test takes all of ten minutes. Making a tester takes about an hour and $20. I suggest getting in gear and doing the test. It will most likely tell you right where the problem is.
Old May 29, 2008 | 08:46 AM
So its just the adjustment screw i have to put teflon tape on?
