is it necessary
Old Jun 1, 2008 | 09:42 AM
mywht03's Avatar
is it necessary
hey all, im jus asking if a walboro double fuel pump is necessary for a gt35r turbo.
i pretty much have all the supporting mods needed
AEM ems
hks 280, arp headstuds, titanium
greddy front mount w/ greddy LICP& UICP
walboro 255 fuel pump
Injen test pipe& Injen catback exhaust with HKS DP 3"
meth
act clutch with flywheel
1000cc injectors
Im still on the stock turbo with 9.8 hotside n decided to go with the gt35r. was going with the fp green but decided not to get it since u would have to build the block to get into the 10's which is my goal. everyday 10' sec 1/4.
I think my act clutch should handle the extra power but jus thinkin if the double pumper is needed.
thanx to all that answer
Old Jun 1, 2008 | 09:47 AM
kanyonkid's Avatar
damn... u should be good.. and i gurantee u'll hit 10's w/ meth
Old Jun 1, 2008 | 10:53 AM
EatSleepBoost's Avatar
not to sure. prob depends on how much boost you plan on running. this should probably be posted in the evo advanced section
Old Jun 1, 2008 | 01:07 PM
bbyevo8u's Avatar
i dont think its necessary but i'm not 100% sure just like eatsleepboost said it depends on boost levels! with you setup i'm guessing around 30psi right
Old Jun 1, 2008 | 02:00 PM
importjake00's Avatar
You should be good
Old Jun 1, 2008 | 03:10 PM
mywht03's Avatar
thanx alot guys. the reason im askin also is because went to a track about a month ago n saw a evo whose rod went through the block cause one of the pumps stopped workin so it leaned out. ever since then i was kinda skeptical n this guy also had a 35r with stock ecu.
