Vp C12
Old Jun 5, 2008 | 08:31 AM
W2J's Avatar
W2J
Vp C12
I got a new barrel from a friend of mine, my question is can I use this on my Evo? I know C16 is design for turbo applications and C12 is more for NA would I see any benfits and whats the most I should push for?
Old Jun 12, 2008 | 10:26 AM
DG Motors's Avatar
That is a very tough question considering I have no idea what is on your car!
Old Jun 12, 2008 | 01:21 PM
STikiller.com's Avatar
You could use it, but yes it is more designed for NA. Also be aware that leaded gas will damage your 02 Sensors faster.
If you want, mix in 4 gallons C12 than the rest with 93. This will raise the octane to a little over 100. You need to retune with some added timing if you want to take advantage of the extra octane, other wise its just a waste.
But atleast it will smell good!
Old Jun 12, 2008 | 02:16 PM
kreionic's Avatar
I run c12 often. Been threw about 23-30 gallons straigh c12 all of my o2 and wideband o2 are still good to go. C16 on the other hand i was replacing my sensors about every 10-15 gallons
