Should I buy this car? (Compression Test Results)
Old Jun 5, 2008 | 12:41 PM
IBAUCLAPlaya's Avatar
Does anybody have the exact FSM values for the two compression tests: Static and dynamic?
Old Jun 5, 2008 | 12:43 PM
crcain's Avatar
Originally Posted by sblvro
you can actually do both. static compression testing(throttle closed) and dynamic compression testing(WOT).
It was my understanding static compression refers to simply your compression ratio, ie 9:1, etc.
Dynamic compression I thought meant your actual compression ratio when factoring things like cams and such which would change your compression ratio because of how much air is let in before compression.
Not sure on all this though.
Old Jun 5, 2008 | 12:44 PM
MR Turco's Avatar
Originally Posted by crcain
You run the test WOT because the ECU will not give the engine any fuel under this condition. Otherwise when you go to start up after the test is done you will get a nice massive backfire because fuel was spraying while doing the test.
?? no you are supposed to pull the cam angle sensor harness so the fuel system is disabled.
crcain's Avatar
And I thought Evo 9 compression checks should be between 130-140.
Under Evo 9 should be around 170-180.
Old Jun 5, 2008 | 12:45 PM
crcain's Avatar
That would work too.
But explain to me why wide open throttle is done then?
Old Jun 5, 2008 | 12:49 PM
crcain's Avatar
Hmm I guess if you did have the throttle plate closed, the piston might have problems "sucking" air into the cylinder.. as there might be vacuum in the inlet. I can't see any purpose to this type of test.
Old Jun 5, 2008 | 12:51 PM
MR Turco's Avatar
It is hard to build cylinder pressure when you dont have a supply of air.
Old Jun 5, 2008 | 12:59 PM
crcain's Avatar
Yes.
I'm quite sure about 100% throttle = no fuel.
Has that function in my Autronic SM4 too.
Old Jun 5, 2008 | 01:13 PM
deadbeatrec's Avatar
evo 9 has same compression as evo 8 correct?
Old Jun 5, 2008 | 01:22 PM
crcain's Avatar
No I don't think so... evo 9 around 140, evo8 around 180. Not 100% on this though maybe someone else can chime in.
Old Jun 5, 2008 | 04:16 PM
SPIN2GST's Avatar
Its not a Subaru.....it will be reliable.
After you get it bring it over so I can see it.
Old Jun 5, 2008 | 05:37 PM
justboosted02's Avatar
BAHHAHHAHAHAHA
wrt reliability
subaru>>>>>>>>>>mitsu
Old Jun 5, 2008 | 06:12 PM
MR Turco's Avatar
subarus are reliable, until you mod them.
Old Jun 5, 2008 | 06:59 PM
RazorLab's Avatar
You are correct. No need to disconnect anything. Just make sure you are WOT, this shuts off the injectors.
No, Evo 9 is lower than Evo 8. Off the top of my head 130-150 for 9, 160-180 for 8
Old Jun 5, 2008 | 08:37 PM
SloRice's Avatar
Originally Posted by justboosted02
BAHHAHHAHAHAHA
wrt reliability
I gaurantee you want to rethink that statement.
Damnit Matt.....just buy one already. Buschur will get you taken care of.
Jovan Caro
Apr 30, 2017 10:52 PM
TurboTylerIX
54
Sep 25, 2013 05:41 PM
Throttle
20
Jan 21, 2012 07:41 AM
wilbdog
32
Aug 25, 2009 12:11 PM
CalebL
22
May 15, 2008 04:50 PM
