boost lag :(
Old Jun 9, 2008 | 09:30 PM
yasir's Avatar
boost lag :(
Dear All,
My bro's evo7 which he recently bought is hitting boost very late on, i can't figure out the problem with it
Its a evo7 with a built block, powerfc, stock turbo, evo8mr intercooler. I'm running 1.5 bar boost.
on the first and second gear we hit 1.3 bar of boost and then in third and fourth we hit 1.5 and 1.53 respectively.
also in first gear i start spooling boost at 3800-4000 rpm which is very late in my opinion since a HKS gt3037s spooled before my turbo and took the lead when i rolled with him even though its a bigger turbo
i'm sure theres no boost leak since if there was the car would not idle correct since its running on AF and its not MAP tuned.
the turbo seems fine, there is no oil or death whine either.
anyone figure this one out please?
thanks.
Old Jun 10, 2008 | 01:25 AM
yasir's Avatar
bumppp
Old Jun 10, 2008 | 09:31 PM
yasir's Avatar
bump
Old Jun 10, 2008 | 09:50 PM
hanahawaiian's Avatar
did u have reflash ecu or stand alone Emanage or emanage?
did u alrendy reflash n tuned? have manual or Electrical boost contorller?
Old Jun 10, 2008 | 11:52 PM
yasir's Avatar
i have a apexi powerfc installed and a blitz sbc i color boost controller.
Old Jun 11, 2008 | 12:37 AM
RoadSpike's Avatar
A car can idle perfect with massive boost leaks, you can have a coupling open up at 5psi and be perfectly closed when there is no boost :P
This car your bro has needs to have a datalog of a run I suspect the tune is knocking all over the place. You may also consider doing a whole battery of tests on it like compression, boost leak, spark plugs, etc to see if everything checks out.
Old Jun 11, 2008 | 12:57 AM
yasir's Avatar
@roadspike: Thanks a lot mate, i will be tuning it over the weekend, the temperatures rise too quickly coz of the hot and humid weather, therefore am running it very little these days.
I suspect the tuning is out, its running very rich at low rpms.
need to link up my laptop n check whats going on with datalogit i suppose.
thanks though.
Old Dec 24, 2008 | 01:09 PM
kaymin's Avatar
ya, my car has a MASSIVE boost leak I can HEAR as soon as the car is boosting at all but it idle's fine!
rjfg
Jan 25, 2014 07:21 AM
David Buschur
85
Feb 12, 2010 10:30 AM
exacc
Jun 29, 2008 09:53 AM
David Buschur
909
Jun 22, 2008 06:20 AM
Falcon350z
63
Feb 7, 2008 01:11 PM
