Vacuum leak? Found lose hose coming off sensor...
What sensor is mounted on the back of the intake manifold? It has 3 small vacuum lines running off. Im guessing it maybe originally goes to stock boost solenoid.
I started car, and its a vacuum leak..
Can I just plug it? or does it need to feed back into Intake Manifold?
ill get picture, im trying to figure out if i should plug it or not
its right next to alternator, mounted on to, or below the intake manifold
Well i cant get my phone down there..... but
Sorry man, I'm at work so I cant see the pic. The way you describe it, it might be the FPR. I'm sure someone will be quick to give you an answer. Are you throwing any codes?
If it's on the passenger side of the intake mani it's the FPR... if it's on the drivers side it's probably the EGR.
Looks like it's on the passenger side so it's probably the FPR. Don't plug that hose... Use a small ziptie or something to hold it on.
