"Help needed" Twin wasegate vacum/boost lines
Old Jun 14, 2008 | 10:33 AM
BillyT/UK's Avatar
Can anyone give me some guidance with the Fullrace twinscroll wastegate plumbing a diagram would be cool
cheers from the UK billy
Old Jun 14, 2008 | 10:35 AM
scorke's Avatar
It's the same as a single scroll with twice as many lines.
Scorke
Old Jun 14, 2008 | 10:37 AM
crcain's Avatar
Billy are you about to start your Full-Race TS 35R?
Old Jun 14, 2008 | 10:41 AM
BillyT/UK's Avatar
So what do you do .Tee them off each other or use a vacum block also where does the top outlet go of the Tial wastegates ???
Billy
Old Jun 14, 2008 | 10:46 AM
BillyT/UK's Avatar
I will next week im still fabing up the dumptubes/down pipe
Billy
Old Jun 14, 2008 | 02:23 PM
scorke's Avatar
Billy
I'd do a vacuum block if you can swing the fab and do it cleanly, I would be surprised if they dont share the same vacuum and boost source but from what I can imagine T'ing them off would work, a block would be cleanest
Scorke
Old Jun 25, 2008 | 03:38 PM
Geoff Raicer's Avatar
the dual wastegates are actually very easy to setup. the best thing to do is to tap the compressor housing to 1/8" NPT or 1/4" NPT and run a barb fitting. from this go to a "t" fitting and run each to the side port of the wastegate.
the top port of the wastegates are ONLY to be used for connecting an electronic boost controller. So you would tap off either the intake manifold or off the compressor housing, then go to the EBC solenoid. from there you go to a "t" fitting and then to the top port of each WG
i hope this helps, email me if you have any questions. thanks billy
