Race Fuel ...Too many to choose form?????
Old Jun 16, 2008 | 09:56 AM
SpunEvoIX's Avatar
anyone have any suggestions to which race fuel is best i noe many people are based on personal preference but i need some input on people that have used many different brands...so far ive been looking into c16...torco 118 and sunoco 116....
Old Jun 16, 2008 | 09:58 AM
Jean's Avatar
Your in Miami.
118 is good.
If you want pm me and ill tell you where to get it from locally.
Old Jun 16, 2008 | 09:59 AM
SpunEvoIX's Avatar
that would be good thanks
Old Jun 16, 2008 | 10:01 AM
jmartinez1170's Avatar
q16 or vp import
Used on most race cars in my area. (Chicago)
Old Jun 16, 2008 | 10:03 AM
SpunEvoIX's Avatar
Originally Posted by jmartinez1170
q16 or vp import
vp imort sounds good but isnt that alot more than most race gas per gallon...how much does a gallon of vp import go for?
Old Jun 16, 2008 | 10:10 AM
crcain's Avatar
I think I paid around 1100 usd for 55 gallon drum of VP Import.
One thing to think about is that, VP Import is such a good fuel, unless you are making A LOT of power, it's probably not needed. Unless your making like over 550 atw I'd probably recommend a 112 or so type fuel.
That said I'm no expert so get more advice. But remember the higher the octane the slower it will burn so you need some serious cylinder pressures to need that slow burn. You will lose power if you aren't needing that higher octane rating.
Old Jun 16, 2008 | 10:13 AM
SpunEvoIX's Avatar
on pump for daily driving i want to be around 500 and race gas around 700+
Old Jun 16, 2008 | 10:25 AM
crcain's Avatar
Well if you are in the 700 range... this is how I thought about it. Because I am on a GT35R which is in the 700 range. I decided I preferred to pay the extra money over C16 to get VP Import just for the added safety margin.
No doubt about it... 120+ is safer then 116 octane if pushing a car on race fuel. You will most likely begin to push the mechanical limitations of the motor before you get the VP Import to det or knock.
Old Jun 16, 2008 | 10:26 AM
SpunEvoIX's Avatar
dam 700 range on a gt 35 what are your mods?
Old Jun 16, 2008 | 10:33 AM
crcain's Avatar
well i mean flywheel power not atw power... no dynos where i live. tuner estimated 700 though. ran 10.9 with 1.9 60 ft on street tires easy shifting and shifting 5th and easing at the end.
mods are 2.4, hta 35r ams kit, ported head, autronic, hks inlet, etc.
Old Jun 16, 2008 | 09:23 PM
SpunEvoIX's Avatar
im torn between vp import and torco 118 someone help me decide before i buy for my tune
Old Jun 16, 2008 | 09:34 PM
evovin's Avatar
http://www.tgill.com/files/rgcc.htm
Old Jun 16, 2008 | 09:41 PM
codean's Avatar
You are not going to need VP import... honestly its not worth the extra money on a street driven car.
If you have your heart set on using an expensive leaded race fuel, use whatever you can get the easiest and the cheapest and provides the octane for the HP goal. As long as its a good name brand it will be consistant.
Old Jun 16, 2008 | 09:48 PM
SpunEvoIX's Avatar
yeah that is true but for daily driving i am going to use pump and for the fun times and track use some race fuel... i'll just stick with c16 or 118 torco most likely
Old Jun 17, 2008 | 01:40 AM
Jspec EVO VIII's Avatar
Q16, i think is pretty potent for street and track.
