CAS discs and crank triggers?
Old Jun 23, 2008 | 08:35 AM
2highpsi's Avatar
Question CAS discs and crank triggers?
I never even heard of this before until someone mentioned it in another thread. It's suppose to eliminate the long cranking on AEMs which is the ONLY thing I dislike about mine. Don't get me wrong, it's not awful. I could live with it, but if this will fix it I would buy it. I searched and could not find any info about it on here. Rather than go OT I just made a new thread to see if anyone knows if they really work, or if any of you guys are using them.
link to what I am talking about: http://bbrooks.doitbig.org/BrooksTun...%20Trigger.htm
Old Jun 23, 2008 | 08:49 AM
crcain's Avatar
Majority of starts my Autronic turns over in what seems like one crank.
Sorry just rubbing it in.
However your AEM has knock control, and Autronic doesn't.
Old Jun 23, 2008 | 09:08 AM
justboosted02's Avatar
post in the AEM forum
Old Jun 23, 2008 | 09:57 AM
DSMu4ia's Avatar
I have the DSM version and can't say enough good things about it.
When Brad was tuning my car a few months ago we swapped from a regular DSM cas disc to his TriggerDisc and the car picked up about 40whp on pump gas with no other changes. Definately not saying this is what is to be expected from this mod, but just stating what we saw with my personal car.
The starting is the most impressive feature. I never realized how much better it started until I was at Buschur's Sport Compact event and heard all the AEM powered EVO's and DSM's there that would sit and crank forever.
Final numbers were very impressive, record actually on a DSM. I have to think the TriggerDisc helped achieve those goals.
Old Jun 23, 2008 | 10:22 AM
2highpsi's Avatar
Wow! I have to give it a try then. The only thing I don't understand is why more people don't use them if they are so great, and they are not very expensive.
Old Jun 23, 2008 | 10:23 AM
itzwolf's Avatar
Did anything need to be modified in your AEM map for this change to this TriggerDisc since it has multiple reference points vs. the 2 on a stock plate? I've thought about trying one of these out for faster startup and such but there really is a lack of information in general about these.
Old Jun 23, 2008 | 10:36 AM
BBrooks's Avatar
Your map will need to modified to run the new Disc, it requires quite a few setting changes
The reason it isn't more popular is that it is new and hasn't really been marketed at all to this point. The EVO9 is still in testing with the Mivec and may actually get a whole different design disc to make full use of increased updating of the intake cam location.
David Buschur now has one and has said he's going to be testing it soon. So maybe in the future it will be more common.
Old Jun 23, 2008 | 10:48 AM
2highpsi's Avatar
The reason it isn't more popular is that it is new and hasn't really been marketed at all to this point. The EVO9is still in testing with the Mivec.
Do you foresee any shortages in product after a review?
I am trying to figure out if I should get one now, or wait till the review
Thanks for the response also!
Old Jun 23, 2008 | 10:57 AM
BBrooks's Avatar
Well, the few we've sold so far everyone has been pleased, but an outside test would be best for an unbiased opinion.
Other than the quicker starting it actually helps ignition accuraccy also, which was one of the main reasons for building it. I'll try and put more info up about that when I get more time.
Also if anyone within a resonable distance to VA would like to do some testing for the EVO9 for a free disc, shoot me an email.
Old Jun 23, 2008 | 11:27 AM
itzwolf's Avatar
BBrooks,
Can you PM me everything I would need to change in my AEM calibration? I have an Evo 8 and am seriously interested in trying this out. I should have my engine back within 2 weeks so while its out I would rather install it then...
Old Jun 23, 2008 | 11:36 AM
2highpsi's Avatar
I am also interested in what all needs changed. Can I just change a couple settings, or I am going to need a full re-tune.
If I install it will I be able to drive it somewhere to get tuned, or will I need it installed where I am getting the tune?
Thanks again
Old Jun 23, 2008 | 11:50 AM
BBrooks's Avatar
The tune can stay the same.
We've tested this a few times now. I have tuned a car fully on a stock 4 tooth dsm disc, then did nothing but change to the 24tooth dsm disc and re-sync timing with a light. The power, A/F and the curve looked almost identical only the curves with the new disc being a little smoother. When we first did Tony's(dsmu4ia) car we actually picked up power, but after doing that same test 3 times now I think his car was just off on timing slightly with the stock disc.
Most of the changes are simply inputting new settings into the cam/crank settings in the AEM.
One other change is made to the cam sensor which involves taking off one tooth from the wheel. This is a simple mod with a dremel tool, all external to the motor and takes about 10mins to do.
I should mention, when you get a disc it comes with a complete .PDF instruction showing everything needed to be changed along with pictures. Also, the disc only fits on cars with the balanceshafts removed.
Old Jun 23, 2008 | 04:05 PM
nukefission's Avatar
The FAQ page on triggerdisc.com should answer most of these questions. We do prefer to furnish the full instructions only to those who purchase a disc. The calibration changes are extensive, but easy to make.
The EVO9 application has a lot of potential. I will echo Brad's call for anyone local who would be willing to volunteer their car for testing.
Old Jun 23, 2008 | 04:30 PM
w_tomas's Avatar
The triggerdisk crank trigger works very well. It was installed in on of my friend's evo by Big Valley Performance. It starts like stock. I wish I would have pulled my balance shafts when I built my motor so I could run one too.
Old Jun 23, 2008 | 06:03 PM
omniprobe's Avatar
You have to run without balance shafts right?
