RNR O2 Housing Exhaust Gasket Help!
I got a used RNR kit from another member. I am trying to bolt up my Buschur down pipe to their O2 houing flange and have no gasket. The shop doing the job used one they had there but it is still leaking a little.
Anyone know what gasket they use or have a solution?
Not the 5 bolt O2 side the 2 bolt that bolts to the down pipe.
hmm it was working
basically you can buy a sheet of gasket material and cut it to your required size/shape
http://www.mr-gasket.com/ProductDeta...ket%20material
the kid i got the kit from said he used a donut gasket...so we are going to try that. a flat gasket will not work. cause the Bushur DP flange is not perfectly flat.
If this does not work they are going to cut both flanges off and put v-bands on it.
