DTM's RB 2.3 and HeadGames Make a Perfect match!!
Old Jul 2, 2008 | 09:53 PM
  #31
red03evo's Avatar
Great numbers.
Old Jul 3, 2008 | 04:37 AM
  #32
DTM's Avatar
DTM
Thanks guys.
Ted B always right on point.
Old Jul 3, 2008 | 04:54 AM
  #33
SPEED's Avatar
She got headgame man...LOL
Old Jul 3, 2008 | 05:48 AM
  #34
crcain's Avatar
What would be the effects of sustained high EGT's?
If you are det free, I can only see a problem with turbo. And if you look at the reliability of turbos in comparison to engines, I don't think I would have much concern of the turbo.
Again I am just total amatuer but just curious.
Old Jul 3, 2008 | 05:52 AM
  #35
TeStUdO's Avatar
High EGT's=Blown turbos and melted valves.
Old Jul 3, 2008 | 05:57 AM
  #36
Ted B's Avatar
So where do you think all that heat goes? Does it all go out the exhaust, or does some of it get transferred to pistons and valves and such?
Old Jul 3, 2008 | 05:59 AM
  #37
crcain's Avatar
Yes but if your det free presumably the exhaust valve temps are in check? I dunno.
I hate to have cluttered up DTM's thread. I was just curious as to how he went about choosing the boost level. And if actually he simply did not make anymore power with more boost. Seems hard to imagine because Buschur motors are 9:1 I think and run 30 psi on 93. While 9.6:1 is not a big jump from there.
Old Jul 3, 2008 | 06:04 AM
  #38
TeStUdO's Avatar
Actually 9.6:1 and 9:1 is a pretty big difference in static compression, even bigger when you are force feeding it with a huge turbo. I'm sure Nick could have made an extreme amount of power by turning up the boost, but it a TA car. It's meant to run at WOT alot of the time. Its called risk vs. reward.
Old Jul 3, 2008 | 06:09 AM
  #39
Ted B's Avatar
When pistons and valves and such are exposed to excessive heat, they begin to absorb that heat, and will do so until the metal surfaces reach the same temp. When this happens, the resulting hotspots will increase preignition potential. When the fuel mixture begins autoigniting, you're done.
There are differences of engineering strategies between endurance racing and drag racing. The motors running 30 psi on 93 octane aren't being subjected to 30 min of WOT events.
Old Jul 3, 2008 | 06:11 AM
  #40
TeStUdO's Avatar
Once again, Ted B puts what I am trying to say in a post alot better than me. Thanks
Old Jul 3, 2008 | 06:21 AM
  #41
xiaoni420's Avatar
I can safely say that he puts things into words alot better than the majority of us.
Old Jul 3, 2008 | 06:35 AM
  #42
crcain's Avatar
I hear ya guys and thanks I understand what your saying.
Old Jul 3, 2008 | 08:55 AM
  #43
HeadGames's Avatar
we could spice this conversation up with some valve seat, valve guide and valve material conversation now that we are talking about heat if everyone is down with it.
Old Jul 3, 2008 | 09:09 AM
  #44
scorke's Avatar
YEs please!!! Inconel? Do tell, whatever your willing to disclose, I am sure porting an OEM head is a good bit science and a little bit art but I would love to learn more!
HeadGames, lots of people and or vendors on here have been selling your machined heads as there own, do you yourself offer the services or just through vendors?
Scorke
Old Jul 3, 2008 | 09:29 AM
  #45
Ted B's Avatar
Given that the originator of the discussion mentioned the use of your head specifically, and being that this is relevant to the discussion, I feel it's totally appropriate.
