Real Problim Car not cranking up
Old Jul 12, 2008 | 10:52 AM
kaonashi's Avatar
Ok about 3 weeks ago now, i was driving and my car just died, and wouldnt crank back up period. It will turn over but it doesnt have a spark on from the plugs, I checked the wiring harness plugs for voltage and both side have voltage, but the spark plugs themselfs are not creating a spark at all. This is what ive checked/done
Changed plugs
Changed Coils
Put all brand new fuse's for ignition components
Checked fuel pump/ fuel pressure
Timing still lines up
Replaced both Cam Position Sensors
now what im wondering is if there is a Ignition Relay on the firewall or are those just 2 fuel pump relays? Anyone else have an idea?
Old Jul 12, 2008 | 11:02 AM
kaonashi's Avatar
im pulling my hair out !!
Old Jul 12, 2008 | 11:06 AM
smokedmustang's Avatar
It's a 15 amp fuse under the dash. cant remember which one. check those out.
Old Jul 12, 2008 | 11:09 AM
I blew a starter fuse (Fuseable link) at an autox, and the car just quit. Had my Mitsu mechanic on hand luckily, so he found the problem quick. not sure if I had anything cranking though. Re check fuses under dash again.
Old Jul 12, 2008 | 11:18 AM
kaonashi's Avatar
ived checked all the fuse's under the dash too nothings burnt out at all.
Might be checking the ecu from problems
Old Jul 12, 2008 | 11:40 AM
Make sure everything is connected securely, then call Chris at Mellon Tuning, he sure helped me trouble shoot my problems! He is great. Good luck.
Old Jul 12, 2008 | 11:48 AM
TOX)(C's Avatar
check grounds
Old Jul 12, 2008 | 01:10 PM
kaonashi's Avatar
Grounds are all secure all plugs are too, im waiting on my buddy to bring my tactrix cable back over so i can try to pull the Codes and check and see if i can still pull my Flash off the ECU. then ill be callin chris
Old Jul 12, 2008 | 01:32 PM
Mellon Racing's Avatar
I sent ya a pm with my phone number...give me a call I have a few ideas about the clutch switch and a potential relay and how to troubleshoot it.
flipflop
Dec 22, 2016 01:56 PM
ghozt
Sep 14, 2016 07:04 AM
ezzey
Jul 19, 2016 04:48 PM
EVOclub4
Nov 13, 2007 06:41 PM
