when is it time to upgrade stock injectors?
Old Jul 12, 2008 | 10:16 PM
Ion619's Avatar
is it time to upgrade the stock injectors when you upgrade the turbo (evoix)? beneficial to stay with stock injector with stock turbo and spend the $$ else where?
thanks
Old Jul 12, 2008 | 10:39 PM
partyboy1122's Avatar
Huh? Upgrade your injectors when your Injector duty is at 100% at WOT
Old Jul 12, 2008 | 10:40 PM
alan678's Avatar
This is best determined by your injector duty cycle....which is done by data logging...
Usually with an intake, exhaust, and higher than stock boost (from 19 to about 23-25lbs) they will be maxed out...or very close to...
Old Jul 12, 2008 | 11:02 PM
evo L's Avatar
might as well be one of the first things you do after intake/exhuast imo. injectors and fuel pump fo sho!
Old Jul 13, 2008 | 11:10 AM
GTijoejoe's Avatar
I feel, the real question is who has maxed out the stock injectors and how much power were you putting down (on which dyno)?
I would upgrade injectors at IDC > 95% @WOT
Just to be safe that I never over heat the injector when I want to drive aggressively consistantly
My $.02
In addition I should add, depending on the dyno used the loading on the street can be different. Your IDC can change from one to another (this has happened to me using an inertia dyno with my GTi, it makes complete sense if you think about it)
Old Jul 13, 2008 | 11:36 AM
chaotichoax's Avatar
on a ix you have no need for injectors until you upgrade the turbo...even with cams and full bolt ons the stock injectors for most tuners are perfectly fine (unless running high than pump gas octane)
can't say too much about the viii as I don't own one but I would assume it's similar as far as stock turbo and bolt ons are concerned
there are certain tuners that do recommend upgrading them
Old Jul 13, 2008 | 10:05 PM
evo L's Avatar
how does that even make sense? with race gas you usually run a tad leaner or the same a/f with just more timing, how would that translate into needing larger injectors?
Old Jul 13, 2008 | 10:55 PM
riceball777's Avatar
race gas = 30+psi of boost and 50+ more hp. more HP = more fuel
