Injector size for E-85
Old Jul 13, 2008 | 06:59 PM
IDRNKV8's Avatar
Question Injector size for E-85
Well, plannin on switching over to e85, did a little research, and purchased a set of PTE 880's along with an AP fuel rail. Now my question is, to run e85 efficiently, you need 30% more fuel above your stock 560cc injectors, so why is it that ppl jump to 1000's and say that no less should be used? Doing the math, 30% more of 560 would be roughly 730, so why wouldnt the 880's work? They CAN be scaled........ Dont wanna get tuned and find out Im in need of more fuel. Should I sell for 1000's, or will they work?........... Need some help ppl, thanks. BTW, its an evo8 w/9 turbo and aaallll bolt ons.
Old Jul 13, 2008 | 07:02 PM
M3EvoBR's Avatar
how much power do you make on pump gas ???
Old Jul 13, 2008 | 07:03 PM
prostcj's Avatar
You're fine. People also say you need a double pumper and a fuel rail. You don't.
Old Jul 13, 2008 | 07:07 PM
M3EvoBR's Avatar
depends on how much power you want ...
Old Jul 13, 2008 | 07:17 PM
IDRNKV8's Avatar
Around 325whp on a MUSTANG dyno, so IDK, prob around 360 on a DJ. I want around 370 on the MD, which might translate to 410 or so on a DJ. Basically, I wanna lock in good 11 sec passes.
Old Jul 13, 2008 | 07:22 PM
Warrtalon's Avatar
You don't need more than 880s, but people say to get 1000s in case you are going to ever go beyond the stock turbo. For instance, if you go all out on E-85 with the IX turbo, you can stay within reasonable tolerances on your IDCs. If you go to a Green, you go beyond those and need 1000s, so since there isn't much downside to 1000s (same cost and can be tuned on stock ECU), then it makes sense to do it.
I personally only did 850s, because I didn't want to have my gas tune (91oct) to be on 1000CCs with stock ECU - it's a little tougher.
E-85 should definitely lock in good 11-sec passes. Mine is a raped ape in both heat and altitude - consistent as hell and more powerful than ever. You'll love it.
Old Jul 13, 2008 | 07:23 PM
mikiblueeyes's Avatar
880s on stock turbo would be bareley enough at about 100duty cycle . absolutely no need for fuel rail. no need for more than walbro pump.
Old Jul 13, 2008 | 07:24 PM
Warrtalon's Avatar
I am at 79-80% IDC on 850s with the IX turbo running 11.5s (118-119mph traps). At sea level, people will make another 40whp, so factor that in to the IDCs.
Old Jul 13, 2008 | 07:28 PM
IDRNKV8's Avatar
Thanks Warr! So u run both e85 and 91? Can I ask why?
Old Jul 13, 2008 | 07:31 PM
Warrtalon's Avatar
91 is our premium fuel here, so it's my fall-back if I'm unable to find E-85 for whatever reason. I haven't used that tune yet, but I have it just like anyone would who runs E-85, since E-85 isn't everywhere.
Old Jul 13, 2008 | 07:43 PM
IDRNKV8's Avatar
So maybe I should just stick with the 880's incase, for whatever reason, I gotta run reg pump gas(91).......
Old Jul 13, 2008 | 07:44 PM
RazorLab's Avatar
FYI I have had good luck with RC1000cc's + stock ECU on a couple of evos now. They honestly run 100% like stock. You wouldn't even know they where RC1000cc's if you weren't told.
They are pretty easy to dial in. I think I had the first set dialed in about 20mins.
Old Jul 13, 2008 | 07:46 PM
Warrtalon's Avatar
That's good to hear, but I don't know if all tuners are as skilled.
Old Jul 13, 2008 | 07:49 PM
2theMAX's Avatar
I agree on going with the 1,000 cc injectors. Why not get a little bigger than you need to have some room to play with down the road if you ever want more power? That way if you ever change turbos again you won't have to by injectors too.
Old Jul 13, 2008 | 07:53 PM
RazorLab's Avatar
If they know how to scale injectors properly, then it's no problem, they where honestly that easy to scale. No tricks, nothing odd about them, etc
