full engine build
Old Jul 14, 2008 | 08:16 PM
crazymidget016's Avatar
full engine build
what parts do i need for a full engine build......so far i got manley pistons and connecting rods, brian crower springs,valves,retainers, and a greddy timing belt, full greddy t67 25g turbo kit, aem meth injection, hks 272 cams, carbonetic single plate clutch, greddy e-manage ultimate....what am i leaving out?
Thanx
Dan
Old Jul 14, 2008 | 08:25 PM
PVD04's Avatar
Bearings
Engine gasket kit
Main studs
Head studs
Water pump (might as well as it's easy to do with engine out)
Oil pump (for peace of mind)
I would ditch the e-manage. You should either stick with flashing the stock ECU or go full stand-alone (AEM, Power-FC, Motec, etc.). Also, if you are rebuilding due to some sort of engine failure you should replace your oil cooler and oil cooler lines.
Old Jul 14, 2008 | 08:50 PM
Ph3n1x's Avatar
yeah leave out the Greddy Turbo kit.
Old Jul 14, 2008 | 08:55 PM
sabastian458's Avatar
1 major thing missing
gasket set
Old Jul 15, 2008 | 05:12 AM
justboosted02's Avatar
Originally Posted by PVD04
Bearings
Engine gasket kit
Main studs
Head studs
you dont need to replace the cooler lines, its easy enough to flush them out with a parts washer.
Old Jul 15, 2008 | 06:57 AM
BBS's Avatar
BBS
If you care for your investment ditch that piggyback now.
Old Jul 15, 2008 | 08:14 AM
jmartinez1170's Avatar
Add to that the greddy turbo it.
AEM and anything other then this turbo kit and HKS's kit
