Need help please
Old Jul 18, 2008 | 08:16 PM
supercharged's Avatar
Need help please
Ok i just finished putting on an IX turbo ported manifold and o2 housing. Now my boost is at 28lbs and i didn't adjust my MBC at all. I have the Hallman MBC under the hood with the big black knob. Witch way do i turn it to turn the boost down and what is 1 full turn = in boost is it 1 turn = 1lbs? Sorry for the stupid question guys but i just want to turn the boost down until i get it tuned then i will leave it at whatever the tuner sets it at.
Old Jul 18, 2008 | 08:28 PM
JakeTheVIII's Avatar
Doesn't it show on the knob? I would guess that if you turned it clockwise(righty-tighty), that it would increase your boost because you're closing more of the valve? I could be wrong but try turning it counter-clockwise and see if boost goes down. Hope that helps.
Old Jul 18, 2008 | 08:41 PM
No it doesn't show on the knob.
Old Jul 18, 2008 | 08:50 PM
Evolessfornow's Avatar
Turn counterclockwise to lower boost. It should thread out to release tension on the spring inside.
Old Jul 18, 2008 | 08:54 PM
Warrtalon's Avatar
The Hallman does have arrows to show direction (up/down), but there's no way to know how many turns is 1psi. That all depends on your system.
Old Jul 18, 2008 | 09:25 PM
Thanks guys
