Exhaust hitting Nut on rear end
Old Aug 20, 2003 | 03:06 PM
tx evo's Avatar
I just installed the Ultimate 3" turbo back / 3" cat.
Anyways, when under full power are when hitting some bumps in the road the Exhaust is hitting a Nut on the Rear End.
From what I can see its not on the nut.
The exhaust is clearing everything else just that dam nut.
Any ideas to correct the problem.
thanks
Old Aug 20, 2003 | 05:29 PM
ou812's Avatar
Take some silicone hose (10mm x 1" long) and put on the end of the nut . Viola ! Instant muffler bearing .
Old Aug 20, 2003 | 05:39 PM
Chris in HB's Avatar
Re: Exhaust hitting Nut on rear end
Ouch - just be glad it's the exhaust.
Old Aug 20, 2003 | 06:00 PM
jfh's Avatar
jfh
thanks
Engine moves within its mounts and also causes exhaust to move on the rubber hangers of its mounts. This causes clearances to change while under load.
I don't have any experience with the Ultimate system, but I experienced similar problems on initial install with of 3" exhaust and fixed it by loosening the system and rotating mid-pipe a little to create additional clearance.
Vishnu later solved the problem by adding a transfer case bracket to the downpipe that keeps it firmly in place during hard cornering and braking.
