help w/ CEL
Old Aug 21, 2003 | 07:22 AM
jman425's Avatar
help w/ CEL
"EGR... insufficient flow"
this was after i had the Evo taken in to have the tranny looked at. the 5th gear synchro is running fine now, but i have this CEL on all the time. had the dealership look it over twice for loose hose/connections but they found nothing.
i've been running the full turbo-back/vishnu xede set-up for weeks before this service w/o a problem, so cant really blame the mods install. what conditions would trigger this CEL ? any ideas ?
Old Aug 21, 2003 | 07:30 AM
chinalfr's Avatar
Did you reset the ECU? Reset ECU and hope this clear CEL.
Old Aug 21, 2003 | 07:33 AM
jman425's Avatar
it's been reset several times by Mitsu and myself. Mitsu resets it using the clear code function of the diagnostic tool and I do it by unhooking the battery for 2 minutes.
Old Sep 1, 2003 | 09:51 PM
bpclements's Avatar
I had a check engine light after I installed my mbc. I checked the stock solenoid and pushed on the connector and it went away. I was going to disconnect it but left it on. Guess it was loose from me pulling on it. Not sure if this will help.
Old Sep 1, 2003 | 10:17 PM
MrKentChu's Avatar
egr
have you done any exhaust work? there are positive egrs which uses the back pressure from the exhaust side to open the egr. if you have a free flowing exhaust, it won't have enough pressure to open the egr..thus insufficent flow !
tada,
kent
