Just had my boost/vac gauge installed....questions
Old Aug 22, 2003 | 12:40 PM
bs's Avatar
bs
i don't think the afc does that. the avcr on the other hand does. the avcr reads boost in bar.
Old Aug 22, 2003 | 01:17 PM
IzenGreyEvo7's Avatar
Ok here we go. It would make sense if the solenoid at the end of the surge tank has a delay that you are experiencing the problems you two describe. I tapped mine pre solenoid, hence why it works. Here are photos showing where to tap.
Move to the passenger side of the intake manifold's surge tank
Notice the solenoid/sensor at the very left. This has two lines running to it. One from the surge tank where you should run the new line. Then a pass through line to the FPR. This is probably
where they tapped. Hence the delayed readings
When you're all done it should be fine. Notice the vacuum reading.
Old Aug 22, 2003 | 01:27 PM
sir lurks alot's Avatar
Originally posted by bs
tap into the line going from the manifold to the BOV.
yes!
Old Aug 22, 2003 | 01:37 PM
bs's Avatar
bs
hey izen thanks for the pics......that is definitely the problem. easy fix though.
Old Aug 22, 2003 | 01:45 PM
Glad I could help.
Old Aug 22, 2003 | 03:31 PM
Daveyd's Avatar
Thanks man...You rock
Old Aug 22, 2003 | 03:54 PM
Both of you know let me know if this fixes your problem.
